Author Topic: Please help me cost up my salvage *UPDATE*  (Read 11864 times)
Offline Craigh1983
    • Leicester Wedding Photographers
Re: Please help me cost up my salvage (GUTTED) :-(
« Reply #15 on: February 20, 2014, 08:31:31 pm »
Saturday,08,February,2014,09:37:03:02513
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: Release 12.12.0 (x64)
Data version: 20130910
VIN: WVWZZZ1KZ6W063666   License Plate: LC55NNK
Mileage: 191070km-118725mi   Repair Order:
Chassis Type: 1K (7N0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 47 52 56 62 72
VIN: WVWZZZ1KZ6W063666   Mileage: 191070km/118725miles
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
04-Steering Angle -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 1010
09-Cent. Elect. -- Status: Malfunction 1010
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: Malfunction 1010
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: Malfunction 1010
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: Malfunction 1010
47-Sound System -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: Malfunction 1010
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: Malfunction 1010
72-Door, Rear Right -- Status: Malfunction 1010
Address 01: Engine        Labels: 06F-907-115-AXX.lbl
   Part No SW: 1K0 907 115     HW: 1K0 907 115
   Component: 2.0l R4/4V TFSI  00 0070
   Revision: --H01---    Serial number: VWZ7Z0E2580322
   Coding: 0403000318070060
   Shop #: WSC 01279 785 00200
   VCID: E3CF0004225CE906691-80B6
2 Faults Found:
005634 - Power Supply Terminal 30
               P1602 - 002 - Voltage too Low - Intermittent
             Freeze Frame:
                    Fault Status: 00100010
                    Fault Priority: 0
                    Fault Frequency: 2
                    Reset counter: 255
                    Mileage: 0 km
                    Time Indication: 0
             Freeze Frame:
                    RPM: 0 /min
                    Load: 0.0 %
                    Speed: 0.0 km/h
                    Temperature: -40.0°C
                    Absolute Pres.: 0.0 mbar
                    Voltage: 0.000 V
049508 - No Communications with HVAC Control Module (J301)
               U0164 - 008 -  - Intermittent
             Freeze Frame:
                    Fault Status: 00101000
                    Fault Priority: 0
                    Fault Frequency: 6
                    Reset counter: 255
                    Mileage: 191072 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 16:27:41
             Freeze Frame:
                    RPM: 0 /min
                    Load: 0.0 %
                    Speed: 0.0 km/h
                    Temperature: 11.0°C
                    Temperature: 6.0°C
                    Absolute Pres.: 950.0 mbar
                    Voltage: 12.065 V
Readiness: 0110 0101
Address 03: ABS Brakes        Labels: 1K0-907-379-MK60-F.lbl
   Part No SW: 1K0 907 379 Q    HW: 1K0 907 379 Q
   Component: ESP FRONT MK60      0102
   Revision: 00T12001
   Coding: 0004738
   VCID: 40856F88138A121ED43-8015
2 Faults Found:
00668 - Supply Voltage Terminal 30
            002 - Lower Limit Exceeded - Intermittent
57511 - Unknown Error Code
            Unknown - 015 -  - MIL ON
Address 08: Auto HVAC
Cannot be reached
Address 09: Cent. Elect.
Cannot be reached
Unable to communicate with address 09. Are you sure the doors are unlocked?
Address 15: Airbags        Labels: 1K0-909-605.lbl
   Part No SW: 1K0 909 605 N    HW: 1K0 909 605 N
   Component: 2F AIRBAG VW8   015 2100
   Revision: 03015000    Serial number: 0038ED0M7Y8N
   Coding: 0012870
   Shop #: WSC 01269 785 00200
   VCID: 37770454464455A6659-8062
   Subsystem 1 - Serial number: 6332MSME0C09616EJ
   Subsystem 2 - Serial number: 6342MSME0C07161ED
   Subsystem 3 - Serial number: 6351HSME08475C1FJ
   Subsystem 4 - Serial number: 6361HSME084D2645A
1 Fault Found:
00532 - Supply Voltage B+
Address 16: Steering wheel
Cannot be reached
Address 17: Instruments        Labels: 1K0-920-xxx-17.lbl
   Part No: 1K6 920 972
   Component: KOMBIINSTRUMENT VDD 1212
   Coding: 0003403
   Shop #: WSC 00011 888 96745
   VCID: EFE77C34FE945D66FD9-80BA
2 Faults Found:
00457 - Control Module for Network (J519)
            004 - No Signal/Communication - Intermittent
01330 - Central Control Module for Central Convenience (J393)
Address 19: CAN Gateway (J533)       Labels: 7N0-907-530-V2.clb
   Part No SW: 7N0 907 530 C    HW: 1K0 907 951
   Component: J533  Gateway H37 0614
   Revision:   H37       Serial number: 250511F1000734
   Coding: 350003
   Shop #: WSC 12345 123 12345
   VCID: 30653F48632A829E243-8065
12 Faults Found:
01336 - Data Bus for Comfort System
            014 - Defective
             Freeze Frame:
                    Fault Status: 01101110
                    Fault Priority: 1
                    Fault Frequency: 254
                    Reset counter: 255
                    Mileage: 191072 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 16:28:38
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 1
                    Fault Frequency: 5
                    Reset counter: 78
                    Mileage: 191073 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 16:40:18
00470 - Combination comfort Databus in Single Wire
            012 - Electrical Fault in Circuit
             Freeze Frame:
                    Fault Status: 01101100
                    Fault Priority: 3
                    Fault Frequency: 146
                    Reset counter: 38
                    Mileage: 191007 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 00:01:18
             Freeze Frame:
                    Fault Status: 00110100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 78
                    Mileage: 191073 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 00:26:24
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 106
                    Reset counter: 78
                    Mileage: 191072 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 01:58:25
01331 - Door Control Module; Driver Side (J386)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 6
                    Reset counter: 78
                    Mileage: 191073 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 16:42:56
01332 - Door Control Module; Passenger Side (J387)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 6
                    Reset counter: 78
                    Mileage: 191073 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 16:29:20
01333 - Door Control Module; Rear Left (J388)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 4
                    Reset counter: 78
                    Mileage: 191072 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 07:54:23
01334 - Door Control Module; Rear Right (J389)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 5
                    Reset counter: 78
                    Mileage: 191072 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 07:45:57
00466 - Control Module for Steering Column Electronics (J527)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 8
                    Reset counter: 78
                    Mileage: 191072 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 01:58:14
01320 - Control Module for Climatronic (J255)
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 9
                    Reset counter: 78
                    Mileage: 191072 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 01:58:14
             Freeze Frame:
                    Fault Priority: 3
                    Fault Frequency: 2
                    Reset counter: 77
                    Mileage: 191007 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 00:00:59
Address 25: Immobilizer        Labels: 1K0-920-xxx-25.clb
   Component: IMMO            VDD 1212
   Shop #: WSC 00000 000 00000
No fault code found.
Address 42: Door Elect, Driver
Cannot be reached
Address 44: Steering Assist        Labels: 1Kx-909-14x-44.clb
   Part No: 1K2 909 144 J
   Component: EPS_ZFLS Kl.5   D04 1606
   VCID: 336F3044523CB986591-8066
1 Fault Found:
00778 - Steering Angle Sensor (G85)
            000 - -
Address 46: Central Conv.
Cannot be reached
Address 47: Sound System        Labels: 3C0-035-456.lbl
   Part No: 1K6 035 456
   Component: 08K Audioverst.     0003
   Revision: 00002000    Serial number: 00000000034819
   VCID: E9D3122CC070B356A3D-80BC
3 Faults Found:
00876 - Treble Speaker Rear Left (R14)
00877 - Treble Speaker Rear Right (R16)
Address 52: Door Elect, Pass.
Cannot be reached
Address 56: Radio (J0503)       Labels: 5M0-035-1xx-56.clb
   Part No SW: 3C8 035 195     HW: 3C8 035 195
   Component: Radio RCD510  040 0166
   Revision: 00000001    Serial number: VWZ1Z3I5445758
   Coding: 0101000001
   Shop #: WSC 00028 028 00001
   VCID: E5CB1E1CEC689736875-80B0
4 Faults Found:
00849 - S-contact at Ignition/Starter Switch (D)
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 9
                    Reset counter: 78
                    Mileage: 191073 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 16:37:22
00625 - Vehicle Speed Signal
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 1
                    Reset counter: 78
                    Mileage: 191073 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 00:05:53
01704 - Terminal 58 (Dimming)
             Freeze Frame:
                    Fault Priority: 6
                    Fault Frequency: 6
                    Reset counter: 78
                    Mileage: 191073 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 16:37:31
00856 - Radio Antenna
            007 - Short to Ground
             Freeze Frame:
                    Fault Status: 01100111
                    Fault Priority: 5
                    Fault Frequency: 1
                    Reset counter: 0
                    Mileage: 178747 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 14:02:41
Address 62: Door, Rear Left
Cannot be reached
Address 72: Door, Rear Right
Cannot be reached
End   ---------------------------------------------------------------------
Offline Craigh1983
« Reply #16 on: February 20, 2014, 08:41:30 pm »
I did speak to Alex at AKS tuning and he said he found a similar problem one time with a car and he basically said it was a write off because if the problems were fixed, there is no garauntee that another fault wont crop up after all that money has been spent on it. And other faults further down the line.
He said its not even a job he would take on... again I don't blame him as it must be a big job!
Offline doylebros
« Reply #17 on: February 20, 2014, 08:42:10 pm »
I've got two modules   - 09 -19
As said FOC.
If it was me I would be getting the fuses in the engine bay checked and then fitting module 9 after I've disconnected all the others and working from there!
Offline Craigh1983
Re:
« Reply #18 on: February 20, 2014, 08:43:33 pm »
Where you based?
Im based in Leicester mate.
Offline doylebros
« Reply #19 on: February 20, 2014, 09:02:02 pm »
So who done the scan:- you, a friend or garage?
Also, if I understand this correctly your car runs and drives but has numerous electrical faults?
Offline Craigh1983
« Reply #20 on: February 20, 2014, 09:07:30 pm »
JohnA from this forum did the scan for me. I then took it to a VW specialist in Leicester (Nass Autos) and they also said I have the modules that are faulty. They said that it could be fixed however it would be time consuming but hes pretty sure he can fix it. I said to him are you 100% sure you can and he said no not 100% but hes pretty sure he can do it. So I couldn't take the risk of him doing all that work for it not to fix it 100% in the end. And with Alex telling me the same thing about it throwing up more problems even after the modules were replaced put me off even more.
Yes the car does run and drives like normal. That's the frustrating thing. Drives beautifully!
Offline doylebros
« Reply #21 on: February 20, 2014, 09:11:12 pm »
Just seems odd to me the ECU didn't go with the rest of the modules!
Offline SI-R32
  • -Receive: 125
Re:
« Reply #22 on: February 20, 2014, 09:13:48 pm »
I don't know how they know 9 are u/s as the gateway can't talk to any of them, after checking gateway fuse to see if OK, I would change gateway, and just check every fuse as a matter of course.
Pity your not near me,  sounds like a good challenge to solve, and as long as engine runs that's the main one sorted
Offline Craigh1983
Re:
« Reply #23 on: February 20, 2014, 09:17:17 pm »
To be honest I don't know if the garage did know for sure that the modules had fried as they didn't strip the car down or anything to get to them. They just basically did a diagnostics on it. I would hope they checked the fuses though. The guy didn't sound very confidant though when telling me all of this. Ended up costing me £76 for having a look at it for me.
Offline Craigh1983
Re:
« Reply #24 on: February 20, 2014, 09:20:16 pm »
It is a real big shame mate cos I could use all the help I could get right now. As you said it could be as simple as changing this gateway fuse? But I am no good with mechanics :(
Would it be worth taking it to another INDY for a second opinion?
Offline doylebros
Re:
« Reply #25 on: February 20, 2014, 09:21:25 pm »
+1 I'm not convinced that's it's no more than as SI-R32 says!
Look I'll send you the gateway see if anyone on the list is close to you like JoeDarka
http://www.mk5golfgti.co.uk/forum/index.php/topic,120.0.html
Just let's know to which address - if you where closer I would come and fit it for you!
Offline Craigh1983
Re:
« Reply #26 on: February 20, 2014, 09:25:39 pm »
JoeDarka is in Manchester I think and I;m in Leicester.
I really hope its this gateway thing! Where are you based?
Offline doylebros
« Reply #27 on: February 20, 2014, 09:29:22 pm »
I'm in Tyne & Wear get your address to me tonight and I'll post it tomorrow!
As I said check the list and ask them who's happy doing electrical fault finding and coding!
Offline SI-R32
  • -Receive: 125
Re:
« Reply #28 on: February 20, 2014, 09:31:27 pm »
Well, that's a difficult decision,  you've gotta hope they know what to do, but they need a good diagnostic tool,  but also be able to fix the gateway first to be able to talk to every other module, it may just be the gateway is the only thing at fault,  it so hard to know
Offline Craigh1983
« Reply #29 on: February 20, 2014, 09:33:31 pm »
Thank you so much for all your help mate! And thanks to everyone on here who is helping me with this. So nice to know there are people out there who will go out of their way to help! :)
