Author Topic: Which are the correct rear discs for my edition 30? Link inside!!  (Read 1215 times)
Offline 18Edition30
http://www.opieoils.co.uk/product-finder.aspx?CategoryID=87&ProductTypeID=80&SEName=brembo-brake-discs#results
I thought the rears were 260mm?
All I see on here is 256 and 282.
Help guys!
Offline DaveB@Vagbremtechnic
  • Trader - 2014
  • -Receive: 130
    • Vagbremtechnic.com
Re: Which are the correct rear discs for my edition 30? Link inside!!
« Reply #1 on: February 20, 2014, 08:19:34 pm »
282mm used to be 286mm either will work
Offline 18Edition30
« Reply #2 on: February 20, 2014, 08:28:25 pm »
On GSF it says 260mm is right for my reg?
So either of the 280s will be fine?
Cheers!
« Reply #3 on: February 20, 2014, 08:30:45 pm »
Listen to the man ^^! /endthread
Offline 18Edition30
« Reply #4 on: February 20, 2014, 08:35:02 pm »
I know I know. Just like to be sure! Now.....
Pads to match
105.5mm wide
Or
87mm wide...I'm presuming the bigger ones?
Cheers DaveB
Offline garrardrj
  • -Given: 76
  • -Receive: 42
« Reply #5 on: February 20, 2014, 08:48:57 pm »
I had the same problem on the website for fronts and rears and gave up
Will go to local Parts place so if they are wrong i can take them back !
Offline 18Edition30
« Reply #6 on: February 20, 2014, 08:58:11 pm »
Never known so many combinations for a mk5 golf!
Help me out guys!
Offline 18Edition30
« Reply #7 on: February 20, 2014, 08:58:38 pm »
Sorted the discs as stated by Daveb.......just need pads confirmed!
Offline 18Edition30
« Reply #8 on: February 20, 2014, 09:13:03 pm »
Any info on pads? Daveb?!
Offline Chris92
  • -Given: 33
« Reply #9 on: February 20, 2014, 09:27:15 pm »
You've got me thinking now, I bought some pads today for the rear and told the guy my gti had 286 rear discs on as my reg on the computer said it didn't exist  :scared: anyways if I have 282 dics will I have the wrong pads or are the pad all the same for what ever rear disc you have on the gti.?
  • Trader - 2014
  • -Receive: 130
« Reply #10 on: February 21, 2014, 01:12:49 pm »
wider ones are for the RS4 7 A4s and A6s
Narrow ones for Mk5 platform
  • Trader - 2014
  • -Receive: 130
« Reply #11 on: February 21, 2014, 01:14:49 pm »
Mk6 which has the 260mm rear disc has a bosch caliper which uses a different pad. Mk5 GTI / Eddy pads uses the lucas TRW caliper
