Author Topic: RNS-510 MFSW what do i need?  (Read 1565 times)
Offline B3n
  • -Receive: 29
  • Boom!!!!
« on: October 02, 2009, 11:20:56 am »
Hey folks
Ive currently got a 2008 58 plate golf 2.0tdi gt sport and Im looking to upgrade the sound system and quite like the idea of the RNS-510 but im a lil bit confused as to what exactly i need to get the system fully up and running. Am i right in thinking that the RNS-510 comes with in built sat nav and phone prep? Im also looking to install a Gti MFSW but only have the normal computer not the full highline do i need the full highline for the MFSW to work correctly? I also have the ipod connection in the arm rest will this work with the RNS-510?
Many Thanks
Ben
Offline vRStu
  • -Given: 90
  • -Receive: 159
Re: RNS-510 MFSW what do i need?
« Reply #1 on: October 02, 2009, 03:50:00 pm »
The RNS510 doesn't include the Bluetooth but it can be added.
You don't need the highline to have the MFSW.
Yes your iPod connection will still work.
Stu...
Offline B3n
  • -Receive: 29
  • Boom!!!!
« Reply #2 on: October 02, 2009, 04:20:34 pm »
Thanks mate
For the sat nav to work all i need to do is buy the aerial and locate it under the dash somewhere is this right or do i nedd to code it in etc?
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #3 on: October 02, 2009, 04:36:40 pm »
Ideally it will need coding, they often do work straight from the box however it very much depends on it's previous coding.  Either way it will still need coding.
Stu...
  • -Receive: 291
« Reply #4 on: October 02, 2009, 10:07:02 pm »
Unless you already have satnav (eg mfd2) then you'll need to tell canbus you have a navigation unit fitted.
If you're retrofitting mfsw, you might wanna consider retrofitting highline too.
