Author Topic: 'G' Diverter Valve.  (Read 1601 times)
Offline letlifeburn
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,79128
'G' Diverter Valve.
« on: February 21, 2014, 04:02:13 pm »
Hey guys. I fitted the forge DV to my golf other day but I ain't so sure of the sound it gives off. I've been told to go with the 'G' valve. So I went into VW York today to see about one and a cruise control stalk.
They took my reg, at first didn't know what a diverter valve was, then he came back with what I was after and said that there system says that only the 'D' is compatible with he turbo attached to my car. Has anyone ever heard of any problems using the 'G' on an 05 GTI?
« Last Edit: February 21, 2014, 05:30:53 pm by letlifeburn »
Offline homesqueeze
  • -Given: 32
  • -Receive: 43
  • Got another Golf!
Re: 'G' Diverter Valve.
« Reply #1 on: February 21, 2014, 05:08:55 pm »
I can only guess that it's another VW dealer that doesn't know much about its cars! I had a rev G fitted on my 05 GTI with no problems. If I'm wrong I'm sure someone will be on here to correct me! Just get an indy to fit it if the dealer won't.
Offline letlifeburn
« Reply #2 on: February 21, 2014, 05:30:41 pm »
I fitted the Forge DV adaptor other day with my cousin so wed just do that again, ive heard that it can improve the cars feel and mpg, is this true?
Offline south
« Reply #3 on: February 21, 2014, 06:03:03 pm »
I ordered a G for my 55 from the local stealership yesterday no issue.
Offline letlifeburn
« Reply #4 on: February 21, 2014, 07:00:36 pm »
very weird, i was told they wouldnt even order the 'G' for me, awesome gti do them if i wanted one, and for less money i think.
Offline Simon_2.0t
« Reply #5 on: February 21, 2014, 07:03:53 pm »
Hi mate, just phone up VW and order with this part number: 06F145710G
I order from my local dealer for my 55 plate no problem. Is the latest revision. I can order for you and post to you if helps.
Si  :happy2:
Offline homesqueeze
  • -Given: 32
  • -Receive: 43
  • Got another Golf!
« Reply #6 on: February 21, 2014, 07:31:05 pm »
It will certainly affect the feel and mpg if your current dv is knackered and you change to a new one. However if your current dv is in good condition then I'm not sure if there will be any noticeable change. If you want a rev g though there's no reason why your dealer shouldn't order one for you even if they aren't fitting it. They should supply any part you want for any VW car.
Offline MJ
« Reply #7 on: February 22, 2014, 12:39:20 am »
from experience:
  • Spec D's leak
    Spec G's eventually fail
    Forge need a slither of grease every now and again to work properly
    DV+ is a load of sh*te
And TPS are your biggest help if you have the right part number.
2005 VW Bora TDI 130 Highline auto. Current mods: 5.5lt washer bottle & black and aluminium A/C knobs & 312mm front brakes and 256mm vented rear brakes.
Next: turborevs SMIC, 20vt pancake pipe and silicone connectors.
VCDS, ODIS, VAS - PC and multi brand diagnostics around Manchester - pm me for help and advice
Offline robern2
« Reply #8 on: February 22, 2014, 12:44:52 pm »
I had the sane experience with my vw dealer. Ordered via ebay in the end
