Author Topic: Knocking noise  (Read 884 times)
Offline Raffhussain
Knocking noise
« on: February 21, 2014, 06:22:14 pm »
Hi,
I have started to get a knocking noise from around the passenger side. When driving on bumpy surface there is a constant noise, sounds like its it coming from the dashboard around the passenger side but i cant pin point exactly where. dont know if its the dash itself or something to do with the suspension.  Also if make a right turn you can also hear like a creaking nosie. I have had the rear wishbone console bushes replaced not long ago along with 4 wheel alignment. The noise was present before and after.
Thanks for the help
Offline Adam-golf
  • Derv!
Re: Knocking noise
« Reply #1 on: February 21, 2014, 06:52:20 pm »
Could be a few things as I've learnt.
Drop links, steering rack, top mounts.
I had a similar thing and it was my drop links luckily
Offline Raffhussain
Re: Knocking noise
« Reply #2 on: February 21, 2014, 07:47:00 pm »
Thanks for the response
I will take a look at the drop links. Cold weather doesn't really help. You say steering rack can also cause it?
Offline Adam-golf
  • Derv!
Re: Knocking noise
« Reply #3 on: February 21, 2014, 07:59:02 pm »
It can. But they are very expensive so your best of checking the running gear which are cheaper to replace first off all
Offline vr6 g3
Re: Knocking noise
« Reply #4 on: March 15, 2014, 09:54:38 pm »
I'd go with the drop links too
