Author Topic: KW V3 suspension.. Quick question  (Read 1035 times)
Offline alextrea
« on: February 22, 2014, 03:41:38 pm »
Just bought some KW V3s and has everything but the rear bump stops, can you use the rear bump stops of the standard suspension on the v3s?
Alex
Re: KW V3 suspension.. Quick question
« Reply #1 on: February 22, 2014, 05:01:43 pm »
You can but they are not right I believe the KW ones are shorter.
If you get in touch with KW (good luck) or one of their dealers they should be able to order some.
