Author Topic: Fitting rear wiper motor on Mk5  (Read 2543 times)
Offline dav1e
« on: February 23, 2014, 06:20:00 pm »
Hi, my rear wiper has stopped working and the fuse is ok - i was thinking of buying a used wiper motor from ebay , has anyone fitted one before and is it easy to remove the tailagate panel etc? Anything I should be looking out for when Im doing it? Any help would be greatly appreciated.
Offline doylebros
Re: Fitting rear wiper motor on Mk5
« Reply #1 on: February 23, 2014, 06:24:16 pm »
Go to section section 6 in this link
http://www.mk5golfgti.co.uk/forum/index.php/topic,10027.0.html
I would be checking the tailgate wiring in the rubber section which flex upon opening and closing.
Also this may help
http://www.vwgolf.net.au/showthread.php?627-DIY-Rear-Wiper-Delete-MKV-Golf
« Last Edit: February 23, 2014, 06:26:29 pm by doylebros »
Offline dav1e
« Reply #2 on: February 23, 2014, 06:30:35 pm »
ok thanks for that I'll have a look at the wiring first - I take it if there is any fault with the wiring it will be fairly obvious to even someone like me who does not usually attempt these things!!
Offline SI-R32
  • -Receive: 125
« Reply #3 on: February 23, 2014, 06:34:04 pm »
no it probably wont be obvious as the copper in the wire inside the flexible boot rubber can break, only way is to measure with a multi meter
Offline doylebros
« Reply #4 on: February 23, 2014, 06:36:47 pm »
When you get the rubber grommet out of the way,they tend to snap when you pull on them if they haven't broken already - what model and year is your car an I'll tell you the colours  of the wires you need to check if you need it?
Offline dav1e
« Reply #5 on: February 23, 2014, 06:41:43 pm »
yes its a 2005 gti
Offline J12spk
  • VW PERVERT
« Reply #6 on: February 23, 2014, 06:48:13 pm »
Interested to know too!
Das Auto
Offline doylebros
« Reply #7 on: February 23, 2014, 06:50:05 pm »
yes its a 2005 gti
PM me your email and I'll email you the drawings
Offline doylebros
« Reply #8 on: February 23, 2014, 06:50:27 pm »
Offline doylebros
« Reply #9 on: February 23, 2014, 06:58:37 pm »
Mailed :-if the files to big for your email provider I can just send the one page but I've sent you all the basic electrical drawing for your car! :happy2:
Offline dav1e
« Reply #10 on: February 23, 2014, 07:00:14 pm »
yes got it all - many thanks
Offline doylebros
« Reply #11 on: February 23, 2014, 07:07:14 pm »
Let's known how you get on  - if you need a motor ask in the wanted section or eBay 1K0 955 711 C  price new £124.63 full retail inc vat  :happy2:
Offline J12spk
  • VW PERVERT
« Reply #12 on: February 23, 2014, 08:38:42 pm »
Thanks a lot buddy
Das Auto
Offline dav1e
« Reply #13 on: February 25, 2014, 08:46:55 pm »
Result! Took car back to the BMW dealer where I bought it in November and they are going to replace the wiper motor on the 6 month Warranty that came with the car
Offline doylebros
« Reply #14 on: February 25, 2014, 09:14:48 pm »
If I was you I would be taking a few photos before hand of your external paintwork (around the wiper blade fixing area) and the tailgate plastic trim internally( the bit with the grab handles), just incase they have a bit of a job changing it! :happy2:
