Author Topic: Epc and engine light but not fault codes.....  (Read 4487 times)
Offline fransnz
  • MY GTI
« on: February 24, 2014, 06:52:32 pm »
Hi guys anyone have any ideas, lights on the dash come up randomly and then go off when the car is turned off (sometimes) have checked the brake lights work as some looking on the net said it might be the brake switch. Please help
Offline Nodz
  • -Given: 73
  • -Receive: 103
Re: Epc and engine light but not fault codes.....
« Reply #1 on: February 24, 2014, 07:12:20 pm »
Do you loose power when this happens? as if the car has gone into limp mode?
Offline fransnz
  • MY GTI
« Reply #2 on: February 24, 2014, 07:26:11 pm »
When the pec light is on yes it goes into limp mode, but not when the engine light is on by itself.
« Reply #3 on: February 24, 2014, 07:52:49 pm »
How did you check for fault codes as if you get an epc light a fault code should be stored in the ecu.
Offline Nodz
  • -Given: 73
  • -Receive: 103
« Reply #4 on: February 24, 2014, 08:14:46 pm »
Sounds like it could be the throttle body.
With mine te EPC light would come on and ESP go off (light on) and loose power then the engine light might come on and ten they would eventually clear and all is fine til they come back. Mine started with them coming on and clearing after turning it off but then happened more frequently.
Best to get it scanned as te fault code will be stored
Offline fransnz
  • MY GTI
« Reply #5 on: February 24, 2014, 08:40:38 pm »
Nodz, what did you do to sort the fault?
Offline Nodz
  • -Given: 73
  • -Receive: 103
« Reply #6 on: February 24, 2014, 10:31:54 pm »
New throttle body, cost ~£400 but before you start throwing money at it get it scanned with VCDS
Offline fransnz
  • MY GTI
« Reply #7 on: February 25, 2014, 01:45:29 pm »
Had it scanned the first time the lights came on but no codes since then.
The codes were
Offline fransnz
  • MY GTI
« Reply #8 on: February 25, 2014, 09:24:17 pm »
It's like I said the lights are on but no error are being read on the car
Offline fransnz
  • MY GTI
« Reply #9 on: February 25, 2014, 10:14:19 pm »
Nodz, what did you try before you went for the throttle body, so far I have only replaced the dump valve (had a huge hole in the diaphragm)
Offline mvb12
  • -Receive: 64
« Reply #10 on: February 25, 2014, 11:04:42 pm »
If you can come south London Crystal Palace I can scan if for you mate.  :happy2:
The 1st one I think is related to the DV. did they rescan after replacing the DV and what DV version did you replace it with?
Does the last comment say "code reset advised"  :confused:
Offline fransnz
  • MY GTI
« Reply #11 on: February 26, 2014, 11:49:05 am »
The valve was 06f145710g and I scanned it with a reader I got online and no faults on that. The codes were reset.
Offline Nodz
  • -Given: 73
  • -Receive: 103
« Reply #12 on: February 26, 2014, 11:54:26 am »
I spoke to Alex at AKS and said he thinks it was the TB with the symptoms I was having and then took the car to him which he scanned and replaced and has been fine since I'll dig my thread out with my symptoms
http://www.mk5golfgti.co.uk/forum/index.php/topic,76837.msg805333.html#msg805333
Offline fransnz
  • MY GTI
« Reply #13 on: March 13, 2014, 09:57:47 am »
Hey There Guys finally bought the vcds software and scanned the car..... and these were the results  :confused:
Any ideas on these codes, think I going to have to get a new throttle body :sick:
will have a look at taking some reading on vcds, just need to have a look on how to do it......
                Address 01: Engine       Labels: 06F-907-115-AXX.lbl
Control Module Part Number: 1K0 907 115 A    HW: 1K0 907 115 A
  Component and/or Version: 2.0l R4/4V TFSI  00 0070
           Software Coding: 040300031C070060
            Work Shop Code: WSC 00302 210 89560
                      VCID: 2447E9DAE74F793EDFF-8071
3 Faults Found:
008487 - Accelerator Position Sensor 2 (G185)
               P2127 - 002 - Signal too Low - MIL ON
             Freeze Frame:
                    Fault Status: 11100010
                    Fault Priority: 0
                    Fault Frequency: 7
                    Reset counter: 255
                    Mileage: 87249 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 13:41:01
             Freeze Frame:
                    RPM: 0 /min
                    Load: 0.0 %
                    Speed: 0.0 km/h
                    Temperature: 43.0°C
                    Temperature: 17.0°C
                    Absolute Pres.: 990.0 mbar
                    Voltage: 11.684 V
005634 - Power Supply Terminal 30
               P1602 - 002 - Voltage too Low - Intermittent
             Freeze Frame:
                    Fault Status: 00100010
                    Fault Priority: 0
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 0 km
                    Time Indication: 0
             Freeze Frame:
                    RPM: 0 /min
                    Load: 0.0 %
                    Speed: 0.0 km/h
                    Temperature: -40.0°C
                    Absolute Pres.: 0.0 mbar
                    Voltage: 0.000 V
008583 - Bank 1; System too Lean at Idle
               P2187 - 004 -  - Intermittent
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 0
                    Fault Frequency: 4
                    Reset counter: 255
                    Mileage: 87790 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 11:36:56
             Freeze Frame:
                    RPM: 853 /min
                    Load: 15.3 %
                    Speed: 4.0 km/h
                    Temperature: 87.0°C
                    Temperature: 43.0°C
                    Absolute Pres.: 1020.0 mbar
                    Voltage: 13.970 V
Readiness: 0000 0000
« Reply #14 on: March 13, 2014, 07:40:14 pm »
I concur it looks like your TB sensor is bad...   :sad1:
