Author Topic: Offset question.  (Read 642 times)
Offline letlifeburn
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,79128
Offset question.
« on: February 24, 2014, 09:46:28 pm »
Im after a set of 18" monzas, and ive potentially found some, replicas i believe, i couldnt see bbs written anywhere on the back.
They are 18x8 and et35, the owner said he fitted them to the car, and when he went over a bump he could hear them hitting against the wheel arch, now i searched and lots of people are using this size and offset on MK5 golfs with no trouble, what can be done to stop this hitting and rubbing? because i really want these wheels, and its annoying ive found them and they arent right.
Offline George10
Re: Offset question.
« Reply #1 on: February 24, 2014, 09:51:18 pm »
Roll or pull the archers
 18x8 et 35 shouldn't be an issue anyway.
Offline xjay1337
  • -Receive: 377
« Reply #2 on: February 24, 2014, 09:56:12 pm »
It will rub on the front under hard bumps at speed or when bumping up/down/over things at low speed at near to full lock especially with 225/40 tyres.
I know this because my GTI came with 18 inch replica wheels which were.... 18x8 et 35 and on the test drive it scrubbed on a big bump at high speed.
They are definitely replicas with that offset and width.
Offline letlifeburn
« Reply #3 on: February 24, 2014, 09:59:52 pm »
so what are the sizes of genuine monzas and shadows then? and how much is it to roll the arches typically and how exactly does that look?
Offline xjay1337
  • -Receive: 377
« Reply #4 on: February 24, 2014, 10:07:17 pm »
17 or 18 x 7.5 et 51...
It doesn't change the look of the arches at all and the prices vary depending on where you have them done. A mate of mine did them for £45 for me... most places charge double that.
Offline letlifeburn
« Reply #5 on: February 24, 2014, 10:18:30 pm »
so if you fitted 215 tyres, thatd give a little stretch look im guessing right? would that help to not rub? Also ive noticed the wheels sit back from the arches, so i want spacers to move them inline with arch, im guessing if you did that with 8's thatd rub like a bitch?
Offline letlifeburn
« Reply #6 on: February 24, 2014, 11:43:20 pm »
after doing some reading up, i came across this site, which helped to tell me what the difference in the new wheels would be.
http://www.rimsntires.com/specspro.jsp
i put the standard wheels as 225/45/17x7 et51, is that right for the 17" monzas on an 05 GTI?
« Last Edit: February 24, 2014, 11:53:17 pm by letlifeburn »
Offline Melkiy
« Reply #7 on: February 24, 2014, 11:50:42 pm »
Pull and roll arches.  I've got 18x8.5j front et35 tyres 215/35 and lts lowered and wing on the same level as tyres and does it rub? Not at all. Maybe 3 time in 2 months that's down the hill on the sharp conner )))
Offline xjay1337
  • -Receive: 377
« Reply #8 on: February 25, 2014, 12:06:11 am »
Please read the guide which is stickied at the top of the page.
http://www.mk5golfgti.co.uk/forum/index.php/topic,19933.0.html
This should answer any and all quesitons you have. If not please post back up (here or in that thread) and I'll try to help you.
215 tyres on a 8 will give virtually no stretch at all but they would give a few MM of clearance... 205/40s would be better.
But you can't just willy-nilly change things unless you know what you're doing.. just stick with genuine wheels to be honest and put 10mm on the front and 15mm on the rear.
Offline letlifeburn
« Reply #9 on: February 25, 2014, 12:58:04 am »
After only just noticing the wheel guide in your sig, i think im all sorted now, the offset was what got me, i thought adding a 10mm spacer would make it et45 and would fit better, but itd actually make it et25.
Offline George10
« Reply #10 on: February 25, 2014, 09:38:54 am »
I ran 19.8.5 and didn't scrape, 18x8 with 215's will be fine, but pull and roll them
Just for a bit extra clearance
