Author Topic: Door mirror  (Read 749 times)
Offline suave
  • -Given: 31
Door mirror
« on: February 25, 2014, 12:50:49 pm »
Folks
The plastic trim removal tool needed to remove the door mirror glass - is it generic or do i need a specific shaped tool?
I have seen sets online - would they be ok for mirror removal?
Offline OEM+ DUB
Re: Door mirror
« Reply #1 on: February 25, 2014, 01:51:34 pm »
Hi there,
No specific shape required but from experience the wider the better.  I have a Facom set of plastic trim tools covering a variety of widths which have been great for all the trim removals on my GTI I've need to do so far.
Hope this helps.
OEM+ 2005 GTI DSG (high factory standard spec and upgraded with S3 alloy hubs, S3 alloy wishbones, Bilstein B8s and VWR springs by my own hands) owned since 2008 and still loving it!
Offline doylebros
Re: Door mirror
« Reply #3 on: February 25, 2014, 04:54:53 pm »
Folks
When I installed my darker coloured mirror indicators I didn't use a tool, just used my fingers.
Set the mirror so the gap between it and the mirror cover at its outer side is at max (mirror turned in towards the car). That should give you sufficient gap to get you fingers below the mirror and gently prise it out.
Offline suave
  • -Given: 31
Re: Door mirror
« Reply #4 on: February 25, 2014, 10:02:40 pm »
Thanks. What about the other bits - torx screws etc - did it come apart easily?
The mossy stuff in mine is driving me mad
Offline doylebros
Re: Door mirror
« Reply #5 on: February 25, 2014, 10:09:17 pm »
