Author Topic: 07 gt tdi intermittent tappet like noise help please  (Read 2154 times)
Offline boarderianb
« on: February 25, 2014, 09:25:53 pm »
I have an intermittent tappet like noise can go days without anything then comes on hot or cold if I go over a big bump in road sometimes goes again sounds loud like old diesel car strange
Ideas anyone
Offline sean76
Re: 07 gt tdi intermittent tappet like noise help please
« Reply #1 on: February 27, 2014, 12:38:00 pm »
Bump  :P can anybody help monkey boy here please coz it's driving him mad  :stupid:
Offline Zseth
  • 05 GTI DSG
« Reply #2 on: February 27, 2014, 03:36:32 pm »
i would suspect it is your fuel lines knocking against the chassis.  Quite common and an easy fix, search on here to find thread
Offline doylebros
  • -Receive: 310
« Reply #3 on: February 27, 2014, 04:41:44 pm »
No knocking fuel lines on 07 GT  TDI - yes on GTI that would be a good shout!
If your saying it's an engine noise my money would be a faulty injector for the symptoms you've described hot or cold or the tank fuel pump beginning to fail!
« Last Edit: February 27, 2014, 05:01:10 pm by doylebros »
Offline boarderianb
« Reply #4 on: February 28, 2014, 10:06:02 pm »
Cheers will look into it asap
Offline S4nup
« Reply #5 on: March 01, 2014, 05:56:45 am »
Had similar issue, turned out to be a worn belt tensioner.
Offline boarderianb
« Reply #6 on: March 02, 2014, 06:12:56 pm »
Had belt and tensioners done last year could it be this already ?
Offline S4nup
« Reply #7 on: March 02, 2014, 06:18:31 pm »
Get your alternator clutch pulley checked. I have a similar issue where I had replaced the tensioner and belt, but the noise came back 7-8months later. Realised that the clutch pulley was jammed. This causes extra stress on the tensioner pulley and causes it to wear prematurely. For me the sound is a very pronounced intermittent tappett noise in the cabin. Kinda subsides in neutral and under a little load
Offline boarderianb
« Reply #8 on: March 04, 2014, 11:39:58 pm »
ok so i looked at the alternator puey today could see any probs there  ?
no noise for a few days then back today eeeergh driving me crazy
