October 02, 2024, 09:16:41 am
All Things Mk5
Sat Nav and Car Audio
rns510 and arm rest mdi...poor sound quality when using mdi
Topic: rns510 and arm rest mdi...poor sound quality when using mdi (Read 1210 times)
Leigh200sx
Always Involved
-Given: 7
-Receive: 6
February 28, 2014, 12:24:03 pm »
Hi I've tried searching and found a few answers but just to clarify Il ask here to... Right last weekend I fitted a rns510,brilliant and much better than my mfd2 which is now in her gt tdi. Yesterday I fitted a arm rest mdi and it's again brilliant, every thing works and all displays on my highline but the sound quality from mdi is piss poor... I've tried cd and sd card and there fine so to is hdd and radio...any help on to finding a solution please
Luka
Always Involved
-Given: 6
-Receive: 32
Re: rns510 and arm rest mdi...poor sound quality when using mdi
Reply #1 on:
February 28, 2014, 01:01:58 pm »
Have a look here mate:
http://www.my-gti.com/688/volkswagen-media-device-interface-mdi-retrofit
In particular, the installation instructions and pin locations.
Sold - 2006 Tornado Red GTI 3dr
Eddie-NL
Trader - 2014
Just look at my post count
-Given: 0
-Receive: 298
My Ride:
Reply #2 on:
March 02, 2014, 07:47:14 pm »
check the settings on the rns
you want to change aux to low
Genuine VCDS VAG-COM HEX-USB + Genuine Vag Commander + Genuine VAG Tacho + Genuine VAG CAN PRO + RNS Manager for Video in Motion and New Pin Code for RNS510
Cluster and Key coding
Location Great Yarmouth
Leigh200sx
Always Involved
-Given: 7
-Receive: 6
Reply #3 on:
March 04, 2014, 09:37:34 pm »
Quote from: Eddie-NL on March 02, 2014, 07:47:14 pm
Done this and it's still terrible..
SI-R32
-Given: 8
-Receive: 125
Reply #4 on:
March 04, 2014, 09:47:48 pm »
are you sure the 3 wires that go into the 510 are the correct way round, when i did mine a very long time ago i found i got them wrong and had to have a little swap around, all way a lot better after, might be worth a try.
GLIDN
Won't Shut up.
-Given: 12
-Receive: 19
Reply #5 on:
March 06, 2014, 09:40:34 pm »
going from RCD300/500 t RCD310/510/RNS510.
Requires two of the wires to be swapped around while the 3rd wire needs to be relocated to a new pin.
All Things Mk5
