Author Topic: Door Rubber Seals  (Read 1023 times)
Offline dav1e
Door Rubber Seals
« on: February 28, 2014, 07:11:54 pm »
Hi, my rear passenger door seal the one on the bottom of the door has come unstuck - does anyone know what is best to stick it back down with so that it gives a good seal and doesn't let water in - thanks
Offline Richie_101
Re: Door Rubber Seals
« Reply #1 on: February 28, 2014, 09:25:23 pm »
I had the same problem about 12 months ago, and I used impact adhesive and I haven't had any problems with leaks or it coming unstuck.
This is the stuff, you should be able to pick a tube up for well under a fiver.  :happy2:
Rich.
Offline dav1e
« Reply #2 on: March 01, 2014, 07:28:21 pm »
thanks for that Rich Ill try some
Offline Zseth
  • 05 GTI DSG
« Reply #3 on: March 01, 2014, 09:53:27 pm »
I just did this to a mates car the other day, just used superglue gel
Worked a treat, impact adhesive should be fine as suggested, poor design by vw for seals to be just stuck o
