Author Topic: Rattling sound inside RNS510 - solved  (Read 998 times)
Offline john87
  • -Receive: 53
« on: March 01, 2014, 09:59:03 am »
Just thought I'd post this in case anyone else has had the same problem with their RNS unit..
I recently bought one off ebay to stick in my mk5. Once it was fitted, I went for a drive and noticed a tapping/rattling sound coming from the unit  :confused: so I took the bloody thing back out again and tried to find the source of the rattle...
I but thr bullet and decided to open the top of the unit (breaking the warranty void sticker) and immediately found the source of the rattle - The built-in hard drive is secured against the left-hand side of the casing by a couple of screws, and the front one was very loose, causing a surprisingly loud rattle when the disk spins up / when the car travels over rough road surfaces.
Tightened up the screw, problem solved!  :happy2: if only all rattles were solved that easily!
Offline Degudodger
  • -Given: 53
  • -Receive: 86
    • Flickr
Re: Rattling sound inside RNS510 - solved
« Reply #1 on: March 01, 2014, 09:07:23 pm »
Glad you got it sorted.  :smiley:
