Author Topic: Replacing OEM parking sensor  (Read 3700 times)
Offline JMP
« on: March 01, 2014, 07:11:05 pm »
My rear center-left sensor is apparently broken, its giving me constant beeps always when backing up. Its coming up as "short to plus" - fault. Has anyone had to replace one? Are the ebay sensors ok to go for? And does anyone know the part number for it, there seems to be a couple of different kind of sensors available and not sure which one to go for. I dont like to remove the bumber first just to check what kind of sensor it is... thanks.
Offline doylebros
Re: Replacing OEM parking sensor
« Reply #1 on: March 01, 2014, 07:27:27 pm »
Could easily be either so this may help!
If it's a harness issue part number 1K6 971 104 E - £72:13
If it's a sensor issue part number 3D0 998 275 A - £86:24
Both items full retail inc vat
However, this is cheap enough to try
http://www.ebay.co.uk/itm/VOLKSWAGEN-GOLF-SKODA-PORSCHE-SEAT-PARKING-SENSOR-BOSCH-NEW-3D0919275D-026003525-/191084795530?pt=UK_In_Car_Technology&hash=item2c7d8a968a
Offline JMP
« Reply #2 on: March 01, 2014, 09:01:23 pm »
Thanks for the tip! Might aswell find me a new sensor before removing the bumper, I can repair the harness but not the sensor. Glad their not that expensive.
Offline MJ
« Reply #3 on: March 03, 2014, 12:47:02 am »
It's pretty much always a sensor issue to be honest. I bought 2 off that seller on eBay and they work a treat!
2005 VW Bora TDI 130 Highline auto. Current mods: 5.5lt washer bottle & black and aluminium A/C knobs & 312mm front brakes and 256mm vented rear brakes.
Next: turborevs SMIC, 20vt pancake pipe and silicone connectors.
VCDS, ODIS, VAS - PC and multi brand diagnostics around Manchester - pm me for help and advice
Offline JMP
« Reply #4 on: May 08, 2014, 08:23:01 pm »
I bought one from same seller. Worked out great. However before changing the sensor I checked the fault codes and in the mean time second sensor had failed :( I just placed an order for another. I wonder what is breaking inside these units.. Well Im pretty fast now in removing the rear bumber!
