Author Topic: Edition 30 air filter same as normal gti  (Read 2116 times)
Offline Vwgticrazy
  • -Given: 41
« on: March 03, 2014, 07:36:34 pm »
Just wondering if they same as normal gti before i buy 1 cheers
Offline Degudodger
  • -Given: 53
  • -Receive: 86
    • Flickr
Re: Edition 30 air filter same as normal gti
« Reply #1 on: March 03, 2014, 08:02:44 pm »
It is.  :smiley:
Offline 56OctyVRS
  • -Receive: 72
« Reply #2 on: March 03, 2014, 08:08:51 pm »
Stick with the oe paper filter
Offline Vwgticrazy
  • -Given: 41
« Reply #3 on: March 03, 2014, 08:45:37 pm »
Thanks for that ,I was thinking of a uprated filter after I get my car remapped do these cause problems then
Offline 56OctyVRS
  • -Receive: 72
« Reply #4 on: March 03, 2014, 09:14:13 pm »
After doing lots of reading up on performance filters and reading lots of independent tests. The pressure drop from a performance filter to a paper filter was 0.09%. Basically there was hardly any difference with flow rates and the papers ability to supply enough air.  A paper filter will always filter better than a performance filter. I ran my car with a K&N panel filter,  then switched to the paper and the car ran better with the paper at stage 2+. I found I had small boost fluctuations but with the paper filter they disappeared.  I would presume it was down to turbulent air going over the maf sensor.
The main restriction with the oe air intake is not the filter. You have to look into other restrictions such as intake tubing, intercooler design, cylinder head design and valve design restrictions. So simply fitting an after market filter will not improve things any.
Offline Vwgticrazy
  • -Given: 41
« Reply #5 on: March 03, 2014, 09:51:11 pm »
Thanks for reply very good of you
« Reply #6 on: March 03, 2014, 10:04:15 pm »
Actually the Ed 30 OEM filter has a different part number to the normal GTI filter.
If you compare the 2 side by side the Ed30 filter is thinner.  :happy2:
Offline Vwgticrazy
  • -Given: 41
« Reply #7 on: March 03, 2014, 11:54:12 pm »
O right thanks i was going to buy a febi 1 off ebay but carnt find any mk5gti ones at all
