Author Topic: Japanese RNS510 model  (Read 2835 times)
Offline Rob1
  • -Given: 40
  • -Receive: 24
« on: March 03, 2014, 09:50:48 pm »
Hi all I have seen the above advertised on eBay, I am not totally clued up on the technical side of things my question is would a unit from japan work in the UK.
Thanks Rob1
Black Ed30
Re: Japanese RNS510 model
« Reply #1 on: March 03, 2014, 10:52:32 pm »
I'm no expert but you need to ensure the tuning frequency scale/increments of that unit matches the UK ones or else your stations will never be properly tuned.
Offline Degudodger
  • -Given: 53
  • -Receive: 86
    • Flickr
« Reply #2 on: March 04, 2014, 07:43:14 pm »
You will also need to update the maps
Offline Viking
  • -Given: 17
  • -Receive: 47
« Reply #3 on: March 04, 2014, 08:01:10 pm »
I know you can't operate a UK spec RNS510 in the States as there are issues, even after updating the maps. Whether it's a firmware issue of not I'm not sure, but I would be inclined to buy one designed and built for this market. I've seen that Jap spec one on Ebay loads of times (I presume he's listing it as a "Rare" one?), and no one else has bought it. That ought to tell you something.
Sarcasm for free. Anything after that can only be considered as a bonus.
Just because you think you know something, doesn't make you an expert if you've just read it on the internet, y'know.
Offline Rob1
  • -Given: 40
  • -Receive: 24
« Reply #4 on: March 04, 2014, 09:17:43 pm »
Indeed it definitely raised my suspicion, however I may have another one built in the uk apparently a 2013 led model.
Ok next question if I buy a unit built for the British market and install it in mk5 would I need to upgrade my standard bee sting aerial, apologies if that's a silly question but my knowledge regarding the rns510 is fairly limited.
Thanks Rob1
Black Ed30
Offline Viking
  • -Given: 17
  • -Receive: 47
« Reply #5 on: March 04, 2014, 09:21:14 pm »
What are you replacing? You shouldn't need to replace the aerial, but you may need to fit a gps antenna if you don't have one fitted already.
Offline Rob1
  • -Given: 40
  • -Receive: 24
« Reply #6 on: March 04, 2014, 10:39:07 pm »
Thanks for the reply Viking, I don't have a gps antenna fitted but just to clarify are you referring the black lead with a square box which would sit just under the dash board?
Thanks rob1
Black Ed30
Offline skard
  • -Receive: 245
« Reply #7 on: March 04, 2014, 10:43:47 pm »
I think Japan use a different bandwidth to the UK, so you might not got many radio stations
Offline Viking
  • -Given: 17
  • -Receive: 47
« Reply #8 on: March 04, 2014, 10:46:19 pm »
Thanks rob1
Yep, that's correct.
Offline Rob1
  • -Given: 40
  • -Receive: 24
« Reply #9 on: March 04, 2014, 10:55:19 pm »
Cheers mate, also once fitted would I be required to have a garage plug in the computer so the unit can be reset with the car?
Thanks rob1
Black Ed30
Offline Viking
  • -Given: 17
  • -Receive: 47
« Reply #10 on: March 05, 2014, 07:41:32 am »
Now that I'm not sure.There might be something to do depending on your existing setup, but I only upgraded from an earlier version to a later one so it was plug & play.
Offline Degudodger
  • -Given: 53
  • -Receive: 86
    • Flickr
« Reply #11 on: March 05, 2014, 08:46:55 am »
My advice would be to buy a unit destined for the Uk/European market as you know it will be compatable. Others may be slightly cheaper but is it really worth the hassle?
If you car doesn't already have a GPS antenna you can buy a square puck antenna for less than £10 which can be mounted just above the stereo but still under the dash. If your car is pre 2008 chances are you will also need a new Gateway which can be bought from Eddie-NL. My advice would be to get it pre coded.
Just my 5p of advice (adjusted for inflation)
Offline Rob1
  • -Given: 40
  • -Receive: 24
« Reply #12 on: March 05, 2014, 06:32:05 pm »
Thanks for the responses guys, my car is a 08 plate registered in March 2008 so I would assume the cambus gateway would be fine. The current set up is the standard radio (RCD 500 I believe) with the iPod adapter in the centre console.
I have found one in the London area priced at £400, it is apparently a 2013 model with the LED's.
« Last Edit: March 05, 2014, 09:30:28 pm by Rob1 »
Black Ed30
« Reply #13 on: March 05, 2014, 10:50:32 pm »
08 model should have a canbus gateway that will not have a battery drain issue with a RNS510.
