Author Topic: RS3 370mm Brakes and Space  (Read 7247 times)
Offline Alzak
« on: March 04, 2014, 12:54:06 pm »
Hi All
Will 370mm discs and brakes from RS3 fit behind 18Inch alloys in Seat Leon Fr ?
Offline scopes
  • -Given: 131
  • -Receive: 115
  • Wolfsburg Edition
    • My GTI
Re: RS3 370mm Brakes and Space
« Reply #1 on: March 04, 2014, 01:12:19 pm »
Think you need the ttrs discs, as the rs3 ones needs rs3 bearings !
Silver is the way !
Offline danishmkvgti
  • -Given: 243
  • -Receive: 154
« Reply #2 on: March 04, 2014, 01:15:35 pm »
That is correct, 10mm wider bearings to my knowledge, you need the TT-RS discs to get it to work
Over the top mod list ;o)
Offline dan930
  • -Receive: 56
« Reply #3 on: March 04, 2014, 02:22:26 pm »
U will need ttrs discs
Part no 8j0.615.301E
MK6 golfR dsg
AKS TUNED
NORTECH PERFORMANCE HTA3071
R TECH custom map
Offline scopes
  • -Given: 131
  • -Receive: 115
  • Wolfsburg Edition
    • My GTI
« Reply #4 on: March 04, 2014, 02:26:13 pm »
After that you could still need to run 10 mm spacers on the front !  :happy2:
Silver is the way !
Offline Alzak
Re:
« Reply #5 on: March 04, 2014, 03:23:48 pm »
Is there any visual difference between RS3 discs and TTRS ?
Offline scopes
  • -Given: 131
  • -Receive: 115
  • Wolfsburg Edition
    • My GTI
« Reply #6 on: March 04, 2014, 04:32:27 pm »
Part numbers !
Silver is the way !
Offline b9rgo1234
« Reply #7 on: March 04, 2014, 05:31:41 pm »
I had TTRS brakes fitted to my Leon with 18" Seat Sport BBS alloy 7.5" ET51 and had to use a 12mm spacer.
The caliper actually rubs on the inside of the alloys though  :fighting:
I plan on using the calipers again but with the fitting kit so I can use TTS 340mm discs.
« Last Edit: March 04, 2014, 05:33:32 pm by b9rgo1234 »
Offline Banham
  • GTI MK6
« Reply #8 on: March 04, 2014, 07:45:20 pm »
Those look amazing  :drool: :drool: May have to  trade my r32's in for some rs3 calipers.
Offline Alzak
« Reply #9 on: March 04, 2014, 08:08:16 pm »
I have oryginal FR 18Inch alloys and I believe they have offset ET45 ...
You mantioned some fitting kit do you have any link where I can see it ?
« Last Edit: March 04, 2014, 08:14:32 pm by Alzak »
Offline dan930
  • -Receive: 56
« Reply #10 on: March 05, 2014, 12:13:37 am »
Aks do the fitting kit for rs3/ttrs calipers fitting to r32 discs or if u want a bigger setup then u can go for the daveb ttrs discs with fitting kit,benefits of the daveb kit is that the discs sits inner(around 4-5mm)& the disc is 32mm compared to 34mm,so u might can get away on not using spacers..not cheap though
MK6 golfR dsg
AKS TUNED
R TECH custom map
Offline pd9264
« Reply #11 on: March 16, 2014, 06:16:39 pm »
I got them behind my monzas with a 10mm spacer
Offline N8KOW
  • Detailer - 2014
    • Kowalski Details
« Reply #12 on: March 16, 2014, 08:10:30 pm »
So will that be similar to Pescaras then?
2014 Mk7 Golf R on Order...
Offline GTI.Dav
« Reply #13 on: March 16, 2014, 08:22:56 pm »
I risked 12.5mm spacers behind my pescaras and they just, just fitted!! Had to remove the wheel weights because they were rubbing on the caliper.
Offline dan930
  • -Receive: 56
« Reply #14 on: March 17, 2014, 12:42:36 am »
I'm thinking of ttrs calipers with ttrs 370mm discs so basically the ttrs setup on my golf R...been reading on American forums that I will need a 10mm spacer to clear the calipers if im running on oem 19x8 tallies but I'm worried that I might get rubbing as I'm lowered on H&R springs...
MK6 golfR dsg
AKS TUNED
R TECH custom map
