November 15, 2024, 11:30:51 am
All Things Mk5
Mk5 General Area
Fitting drl strip
Topic: Fitting drl strip (Read 573 times)
timwills17
Taking part
-Given: 0
-Receive: 2
Fitting drl strip
March 04, 2014, 04:00:54 pm »
Afternoon all,
Any ideas on how to install/wire a drl strip to golf mk5 without auto lights? Would like them to come on with engine on but cut off when dipped beam headlights are switched on. Is this possible?
andy7ven
Always Involved
-Given: 9
-Receive: 30
Re: Fitting drl strip
Reply #1 on:
March 04, 2014, 05:35:53 pm »
I might be wrong but I though these were wired to sidelights? You may be better off buying a kit then all you have to do is connect to the battery and tap into the correct headlight wire. They'll then come on when the engine starts. Philips do one where they'll also dim when the headlights are activated...
Biggest problem is where to mount them without making the car look tacky
Last Edit: March 04, 2014, 05:38:58 pm by andy7ven
All Things Mk5
Mk5 General Area
Fitting drl strip
