Author Topic: Whos cut down the oil filler neck thing?  (Read 6987 times)
Offline cuprak1
  • Cupra k1 - 360 bhp/360 ft-lbs
    • London web design
« on: October 05, 2009, 05:24:56 pm »
Basically when you install an intake and take the OEM engine cover off you are left with a massive tube where the oil caps goes onto.. its a pritty lame design but basically its just an extention and the oil cap will screw into the block (valve cover) once the neck is removed  :pomppomp:
filler neck still in place
filler neck snapped off :)
SpeedStats iPhone app  - AVAILABLE NOW!
View my Cupra k1 project thread here! 360is
Offline vRStu
  • -Given: 90
  • -Receive: 159
Re: Whos cut down the oil filler neck thing?
« Reply #1 on: October 05, 2009, 05:27:16 pm »
All ok until you need to return to standard.  I guess if you keep the longer neck you can put it back on.
Stu...
Offline cuprak1
    • London web design
« Reply #2 on: October 05, 2009, 07:10:30 pm »
yeah you can just re fit it the same way VW SEAT AUDI fitted it over the standard one in the 1st place
Offline cuprak1
    • London web design
« Reply #3 on: October 06, 2009, 12:46:46 pm »
better pic of the oil cap with no filler neck
Offline cuprak1
    • London web design
« Reply #4 on: October 13, 2009, 04:26:26 pm »
Thought i would beef this up a bit more
1) First remove the oil cap and look at the bottom to make sure at the bottom there are notches for the cap to plug in down there (I'm not sure if all 2.0t's have these at the bottom. Please ensure before you move on. If your not sure take a picture of down in there and send it to me and I'll look to see if they are there). The notches should be at the bottom and look something like this. (red outline) PS I also have no idea if the new TSI or TFSI have these attempt at your own risk!!
2) Once you are sure that your car has that warm the car up to normal operating temperature.
3) Once it's heated up cut the car off.
4) Remove the oil filler cap and stuff a lint free rag down to the bottom to prevent dust, glue, etc from falling in.
5)Now use a big set of channel lock pliers and squeeze around the bottom (by the notches) of the oil filler spacer. Don't turn the channel locks as that will just scratch the plastic. Instead squeeze until you hear a click from the glue cracking; once you hear the click just do that all the way around.
6) The oil filler spacer should now just lift freely. Just remove the rag, make sure it's clear down there and put the cap on Ta-da. And now some before and after.
Before:
After:
Offline SteveyD
« Reply #5 on: October 13, 2009, 09:23:30 pm »
Thats a great write up!
If/when I go down the induction route this will come in very handy.
« Reply #6 on: October 13, 2009, 09:28:05 pm »
Done yours yet?  Like the look of this :D
Offline cuprak1
    • London web design
« Reply #7 on: October 13, 2009, 11:42:43 pm »
mines done yah, just remember next time you have been out in the car for a drive when your home to do it, so the glue around this plastic neck has softened enough to twist out
Offline LC5F
  • -Receive: 80
« Reply #8 on: August 08, 2021, 05:50:31 pm »
Holy 12 year thread revival
Stubbled on this last night - not seen it before, I bobetted my oil filler neck today with heat gun and some light hammering.
Too good a mod not to get a bump - back in 2009 a minority would be running intakes, now 2021 that will have flipped the other way
« Last Edit: August 08, 2021, 05:52:04 pm by LC5F »
