Author Topic: Belt slipping?  (Read 2038 times)
Offline doylebros
Re: Belt slipping?
« Reply #15 on: March 23, 2014, 08:37:11 pm »
Hi all, @jakex181 can you describe the sound ? I've had a what I can describe as a hi pitched squeal and it always happens at 2000-2250rpm in second or third gear ? Does that sound similar ? It's annoying and needs looked at, just wondering if this could be the pulley clutch ? It is slightly intermittent like doylebros says. @ doylebros the tensioner is that the aux belt tensioner your referring to ? Cheers
Yes the aux belt tensioner was what I was referring too!
This alternator clutch noise was coming and going for weeks but couldn't pin point it so just fitted the part - now no more intermittent noise - by the way I bought the tool which made it an easy install!
Offline jakex181
Re: Belt slipping?
« Reply #16 on: August 30, 2014, 01:32:52 pm »
Sorry for the late reply, yes my issue happens during the same rev range. am i best taking it to a garage or should i change the tensioner and belt?
