Author Topic: Led valeo coding advice  (Read 3561 times)
Offline D3hnt
« on: March 07, 2014, 12:05:23 am »
As above, on the outer taillights. how do you code out the centre light. Just leaving you with the outer ring. When on side lights, as it also is the brake light?
I can get the outer ring to turn off but not the centre
Can this be done
I have not done the inner led mod as of yet
Hope you can help
Offline Shoy1980
Re:
« Reply #1 on: March 07, 2014, 12:36:24 am »
Can't you take the bulb out and clear the bulb error code?
Offline SI-R32
  • -Receive: 126
Re:
« Reply #2 on: March 07, 2014, 06:58:30 am »
Can't remember what bit it is but in the cecm your looking for something like use break light as tail lights, reduce the % to zero,  click do it,  turn lights on,  that's it
Offline D3hnt
Re:
« Reply #3 on: March 07, 2014, 03:19:59 pm »
The outer taillights are full led, you turn it off with vagcom, which im struggling to do
Offline D3hnt
Re:
« Reply #4 on: March 07, 2014, 03:29:23 pm »
If only i knew where to find it, must off spent an hour last night trying different things
Offline SI-R32
  • -Receive: 126
Re: Led valeo coding advice
« Reply #5 on: March 07, 2014, 03:31:29 pm »
this is where you do it mate
Offline D3hnt
« Reply #6 on: March 07, 2014, 04:52:24 pm »
So thats in central convenience (46)?
Shall i copy the photo, as in 0x1=0 value
Offline SI-R32
  • -Receive: 126
Re:
« Reply #7 on: March 07, 2014, 05:01:16 pm »
Just change your value to zero and enter it , then they won't light up
Offline SI-R32
  • -Receive: 126
Re:
« Reply #8 on: March 07, 2014, 05:12:15 pm »
Should have said no its in 09 Electrics, which is lights and stuff,  46 is locking and alarm and stuff
Offline D3hnt
Re:
« Reply #9 on: March 07, 2014, 06:35:30 pm »
Ok, thanks. I'll give it a try tomorrow
Thank you
