Author Topic: Removing the green mould from the window seals.  (Read 5422 times)
Offline Mk5Dom
« on: March 07, 2014, 08:24:21 am »
Can anyone recommend a good product to remove/reduce this?
I know it's for internal use but I have some ValetPro Enzyme Odour Eater in the workshop which I'm led to believe has the capabilities to remove mould. Will this work?
Re: Removing the green mould from the window seals.
« Reply #1 on: March 07, 2014, 09:18:50 am »
An old toothbrush with some APC will do the trick  :happy2:
It's good practice to go over all the rubbers with a detailing brush and APC before the sno-foam stage if you are doing an intensive wash.
If you are just doing a regular wash try to get into the habit of brushing over all the rubbers, grill, lights, fogs, glass, mirrors, door shuts, petrol cap, etc, etc using the sno-foam.
Just spray on the foam, leave it to dwell for 5mins, and then go round with the detail brush on the parts I listed above.
Then rinse.  :wink:
These are the type of brushes for the job...
http://www.polishedbliss.co.uk/acatalog/raceglaze-detailing-brush-set-cat25.html
  • -Receive: 291
« Reply #2 on: March 07, 2014, 09:38:41 am »
I do the same with my car. Except I snowfoam first and then pretty much immediately go round with a brush as above. Every crease line, panel gap etc.
Offline scopes
  • -Given: 131
  • -Receive: 115
  • Wolfsburg Edition
    • My GTI
« Reply #3 on: March 07, 2014, 10:00:10 am »
A power washer in around that area will also help remove the mold...  :sick:
Silver is the way !
Offline Mk5Dom
« Reply #4 on: March 07, 2014, 10:26:29 am »
Thanks for your replies chaps. I will use a detailing brush to agitate I guess.
  • My Ride: https://www.mk5golfgti.co.uk/forum/index.php?PHPSESSID=70qkhm23hn62l7oaf778m54c6p&/topic,19740.0.html
« Reply #5 on: March 07, 2014, 10:38:05 am »
I always try to avoid aiming the power washer at window seals.
« Reply #6 on: March 07, 2014, 11:32:55 am »
Blowtorch.  :innocent:
Offline sootpig
« Reply #7 on: March 07, 2014, 11:56:38 am »
Ive used g101 and either a toothbrush or a paintbrush :happy2:
Offline scopes
  • -Given: 131
  • -Receive: 115
  • Wolfsburg Edition
    • My GTI
« Reply #8 on: March 07, 2014, 12:12:07 pm »
Just depends how caked on the mould is, but i do like to make sure that area is kept clear from small stones, sand etc, just to prevent scraping the windows...
Looks like the toothbrush is coming out to do the job !
Silver is the way !
Offline sootpig
« Reply #10 on: March 07, 2014, 05:00:18 pm »
Remember not to use your own toothbrush :signLOL:
« Reply #11 on: March 07, 2014, 05:01:36 pm »
Use the wifes?
Offline sootpig
« Reply #12 on: March 07, 2014, 06:15:17 pm »
Use the wifes?
Why the ? Its essential  :signLOL:
Offline GTIKKM
« Reply #13 on: March 07, 2014, 07:09:51 pm »
warm water and soap will do it. Treat all rubbers with rubber care and then your sorted
Offline Stevepd
  • -Given: 49
« Reply #14 on: March 07, 2014, 07:59:40 pm »
Fill the gaps with superglue = water trap solved :rolleye:
Standard 5 Door Shadow blue.
