Author Topic: Induction Kits  (Read 8707 times)
Offline irish_ram
  • -Given: 200
Induction Kits
« on: March 10, 2014, 11:41:25 am »
I have been looking around at a few Induction Kits for my car mainly to improve the the air intake but also to have a nicer sound when accelarating.
I know it will not improve bhp so wondere what my options are as have seen basic ones for £40 up to a few hundred
Offline xjay1337
  • -Receive: 377
Re: Induction Kits
« Reply #1 on: March 10, 2014, 11:44:59 am »
Evoms , ITG or Forge twintake.
Offline edjbreeze
Re:
« Reply #2 on: March 10, 2014, 11:46:05 am »
I have a k&n typhoon that i'm very happy with.
Sent from my RM-821_eu_euro1_276 using Tapatalk
Offline edd666999
  • -Receive: 89
Re: Induction Kits
« Reply #3 on: March 10, 2014, 11:55:25 am »
There are DIY threads somewhere.
Offline irish_ram
  • -Given: 200
Re: Induction Kits
« Reply #4 on: March 10, 2014, 12:57:12 pm »
I presume you mean in the how to guides in here so I will have a scan.
Have seen articles where it mentions making one yourself. Might have a look and see if my limited skills could stretch to it
Offline SurreyED30
Re: Induction Kits
« Reply #5 on: March 10, 2014, 12:58:50 pm »
I made my own it's in my build thread  :wink: very very simple to make up mate
Jake
Offline irish_ram
  • -Given: 200
Re: Induction Kits
« Reply #6 on: March 10, 2014, 01:06:56 pm »
Jake
Cheers, do you have a link to your build thread as could not see it in your sig : )
Offline SurreyED30
  • -Receive: 427
Re: Induction Kits
« Reply #8 on: March 10, 2014, 01:58:24 pm »
Really depends on your budget? Bank on £250-£420 ish for a tried and trusted one.
EVOMS makes very good CAI and it costs around £300, ITG/VWR and REVO CAI's are around £400 each. Don't bother with the Forge Twintake or the cheap REVO or the AMD one. Some of those homemade ones look good too just make sure you buy the section that attaches to the turbo (from Forge) as the MAF sensor ideally needs to be in a certain place IIRC.
I've had the ITG Maxogen, the EVOMS and now have the latest REVO one. As mentioned, they're all good. EVOMS for cha cha cha, ITG for a pronounced impression of Darth Vader's whooosssssh diiisssssssshh and the REVO for something in the middle of the 2.
Offline fab5freddy
  • -Given: 238
  • -Receive: 239
Re: Induction Kits
« Reply #9 on: March 10, 2014, 02:04:26 pm »
Can i ask why you think that Martin?
  • -Receive: 427
Re: Induction Kits
« Reply #10 on: March 10, 2014, 02:47:58 pm »
^^^^ with CAI's its all about the flow (so I'm led to believe) and the Forge one don't do that as well as the others, ie 2 closed canisters, 1 of which faces to the side of the car and the other filling up with all sorts of detritus from the front. Form over function IMO.
No doubt someone with a graph will come along to prove me wrong.  :laugh:
Offline xjay1337
  • -Receive: 377
Re: Induction Kits
« Reply #11 on: March 10, 2014, 03:11:26 pm »
They will!
http://www.mk5golfgti.co.uk/forum/index.php?topic=9988.0
Offline irish_ram
  • -Given: 200
Re: Induction Kits
« Reply #12 on: March 10, 2014, 09:08:10 pm »
What specific parts would I need for a DIY intake. I am thinking of buying the parts separate but want to make sure I am getting all the bits. I have seen some cheap induction kits going on which if not for my specific car then I presume I could use some bits which are universal and likely have to find alternative housing etc to fit in my car.
I am thinking all I need is
CONE AIR FILTER
FLEXIBLE or RIGID COLD AIR HOSING
SOME JUBILEE CLIPS
SOME MOUNTING BRACKETS
SOME SILICONE HOSE ADAPTORS
One kit I have seen is this PART NUMBER- ACCDA85-150  which looking on the site it says Universal but presume I would need to buy the relevant hosing and brackets?
Offline 56OctyVRS
  • -Receive: 72
Re: Induction Kits
« Reply #13 on: March 10, 2014, 09:19:58 pm »
But also it depends on what IC is fitted and other parts. The intake is but one restriction on air flow. Others are inlet pipes, boost pipes, IC design and also the design of the head and valves. Plus you need to make sure the intake has a properly scaled maf housing to ensure it has the correct trim readings. Even being of slightly out  can have a massive effect on how the engine operates. I found that just by  changing all the engine mounts changed the sound of the engine with the oe airbox.
I am not a big believer in intakes on road cars as you do sacrifice low end for top end power. I always look at what part of the power band you drive in everyday.  99% will be below 4000rpms so you don't really benefit from an intake. Plus when I went from an intake to the oe cover. If you want more noise Id change the exhaust. You wont notice the 10ish bhp you lose top end without an intakes but you will notice the loss in low end torque.
Offline irish_ram
  • -Given: 200
Re: Induction Kits
« Reply #14 on: March 10, 2014, 09:36:28 pm »
Sorry to be  :stupid: but I am not sure if that reply was to me or another post as did not understand most of it  :ashamed:
If it was to me and sorry if it answers above but what I am trying to work out is of the parts like the cone, housing, air intake hose etc what is actually universal and what is specific to the car you need to put it on. I mean for instance parts like the hose adapters and clips I presume are totally universal as opposed to the cones fileter which may need to be an exact size for your specific car. I might be talking crap though  :happy2:
