Problem is the OEM radio simply can't provide the same quality of output. You can play endlessly with the EQ but it'll never sound as good. That's why no high end stereo set up of any of the audio cars has a stock HU.
Most aftermarket ones look crap but the standard looking touch screen HUs look really good. Pioneer and Kenwood make some nice ones.
That is correct, but if you use an Audison Bit.One, rockford fosgate 360.3 or JBL MS-8/
It de-EQ's the signals and than applies EQ on them.
However, if you use the low level output on the RCD310/510 or RNS510 you can set the EQ to linear. So there is no processing at all.
Which will help you start with as clean a signal that the OEM radio's can offer.
I completely understand what you are trying to say however. If I was able to get Bluetooth handfree to work via RCA output on radio's I would.
Double DIN unit's I really do not like at all. The only other solution I have found that sort of works is the Alpine CDA-9887 With KCE-BT400 bluetooth.
It's sound output however is no where near that of the older 9815/35 or even 7998 Units.
If I could get my OEM steering wheel buttons to work with my 7998, I would be running that unit for sure.
You would need a lot of fuel in your car to visit squeeguk hasn't he moved back to south Africa or oz
Really? I have not spoke with him for a at least 2-3 months. It would be a shame.
To the OP - Let us know how you get on.
