Author Topic: Hard to select 1st and sometimes hard to remove from 1st  (Read 2719 times)
Offline r88jrd
« on: March 10, 2014, 08:22:25 pm »
I've got a golf mk5 Tdi 2.0l BKD 6speed
Ive been having some issues lately with selecting first gear and sometimes getting out of first gear in slow moving traffic
Best way to describe it is the gear stick just won't push into first (asif I'm not using the clutch) sometimes it won't even come out of first gear
I've also noticed it seems to do it when then I've been in the car a while and in slow moving traffic
Today It started doing it again I worked out if I put the car in 3rd pull out then put it in 1st it goes in gear every time :s
I've
Reset the gear links
New clutch
New flywheel
New concentric slave cylinder
New master cylinder behind the pedal
New fluid
I'm now beginning to guess this is a gearbox issue
Can anyone please shed some light on this
Many thanks
Jordan
Offline martin@gti.co.uk
Re: Hard to select 1st and sometimes hard to remove from 1st
« Reply #1 on: March 16, 2014, 07:34:17 pm »
By the sound of it ...it probably will be gearbox related, as you have done a lot already..try new gear oil for the gearbox. Probably sincro/ bearing wear. Cheapest opt is get 2nd hand one..
Offline doylebros
« Reply #2 on: March 16, 2014, 07:39:21 pm »
I wonder how many miles the vehicle has covered?
Offline Veee-dubber
« Reply #3 on: March 16, 2014, 07:44:00 pm »
Sounds like your in my boat pal, new gearbox needed  :sad1:
Offline doylebros
« Reply #4 on: March 16, 2014, 07:45:31 pm »
How many miles has your box covered and is it 6 speed?
Offline Veee-dubber
« Reply #5 on: March 18, 2014, 09:56:00 am »
Yea 6speed, 05, just touching 100k pal
Yours?
Offline Jayy26
« Reply #6 on: March 18, 2014, 05:09:39 pm »
gearbox synchro??
Offline biffobear
« Reply #7 on: March 18, 2014, 06:48:37 pm »
Its not something stupid like the friction plate fitted the wrong way round
Offline Llew
  • -Given: 45
« Reply #8 on: March 21, 2014, 04:20:01 am »
There's a place near heathrow that recons gearboxes if that's any good to you
Golf 2006 tdi 140pd, dsg paddles,blue interior led lights,r32 rear bumper, cruise control,vcds,highline , r32 mfsw steering wheel, gti front bumper,miltek decat.
