Author Topic: Good quality subwoofer to go with Alpine monoblock amp?  (Read 1678 times)
Offline sanj
  • -Given: 17
« on: March 11, 2014, 06:24:53 pm »
I have just upgraded the system in my Golf 'R' to a top of the range Alpine,speaker's in the MK6 are 10 time's better than a MK5 but I still want a little bit more bass so have managed to pickup a Apline monoblock amp but am wanting to know what sort of sub to pair it up with?My mate swear's by JL Audio but I thought of sticking with Alpine! :smiley:
Offline GLIDN
Re: Good quality subwoofer to go with Alpine monoblock amp?
« Reply #1 on: March 11, 2014, 11:09:45 pm »
Can you post alpine mono block model number so I can asses the power ratings. Then I will be able to best advise.
There are much better options than the Alpine subwoofers these days I'm afraid to inform you.
JL Audio subwoofers, have a very unique sound. People other like it or hate it.
Happy to provide a few suggestions once I have amplifier model and or specs.
Offline sanj
  • -Given: 17
« Reply #2 on: March 12, 2014, 07:20:09 am »
Hi,Thank you for your reply the amplifier is a Alpine V power MRP-M352 700w mono amplifier.
Offline GLIDN
« Reply #3 on: March 12, 2014, 09:28:37 am »
Ok the 4 ohm rating is simply not powerful enough to run any decent sub.
The 2 ohm load is around the 300-350 wrms. this give you more options to work with.
Now before I recommend a SUB. Do you care how much space gets used?
If not, I have a great suggestion.
If you want sound quality over anything else. I have an idea.
Or do you want some authority in the subwoofer?
What kind of music do you tend to listen to, this also plays a big part in choice of subwoofers.
Offline sanj
  • -Given: 17
« Reply #4 on: March 12, 2014, 07:40:00 pm »
Hi,I listen to mostly R&B so some nice clean bass would be ideal!I don't want it to take up a lot of space so was thinking of a single 10" or 12" sub,let's forget about the Alpine amp and say what would you say would be a good sub/amp combo? :smiley:
Offline GLIDN
« Reply #5 on: March 13, 2014, 10:45:52 am »
if you want to occupy as little space as possible. Which will also work with your current amp
http://www.rockfordfosgate.com/products/details/r2s-1x10
If you want a sub that can play what you want has a slightly larger box than the above suggestion
http://www.imagedynamicsusa.net/id.html The ID10v4D4, which will also work fairly well with your current amplifier.
Works well in 0.5-0.6ft3 sealed
BUT, if you want a sub that can play anything, and I mean anything. Sound BLOODY ASTONISHING on everything.
http://www.imagedynamicsusa.net/id-max.html   - Use 1.1ft3 sealed for best result
The IDMAX can play anything and do it extremely well. It's rated around 1000wrms. But 350-400 makes it sing well.
I can also provide other suggestions if some these are a little hard to track down.
Offline sanj
  • -Given: 17
« Reply #6 on: March 14, 2014, 06:35:12 pm »
Hi, thanks once again, I could go for a sub which would take up a little more space as my boot stays empty most of the time, I've since  sold the Alpine a part so can get a amp and subwoofer which h would be more suited to my needs.
Offline sanj
  • -Given: 17
« Reply #7 on: March 18, 2014, 06:44:41 pm »
Sold the Alpine and bought this for £250!
http://caraudiosecurity.com/hdp-1-1000w-mono-d-class-amplifier
Offline GLIDN
« Reply #8 on: March 31, 2014, 05:57:50 am »
Very nice choice in amp. So what are you going to mate it to?
Hertz, focal or Gladen sub woofer?
Offline sanj
  • -Given: 17
« Reply #9 on: March 31, 2014, 07:02:10 pm »
Been looking at the 12" Hertz as it would be a good pairing with the amp,maybe this one?
http://caraudiosecurity.com/es300-3-12-energy-line-subwoofer
Offline GLIDN
« Reply #10 on: April 01, 2014, 09:41:25 am »
that should sound really nice. these day's 10" do a really good job. But like before if no space constraints.
get whatever tickles your fancy.
