Author Topic: URGENT DV question!  (Read 1481 times)
Offline OLLIE_JETTA_MK5
URGENT DV question!
« on: March 13, 2014, 09:32:28 am »
Just ordering a dv for my gti ! its a 2006 ko3 , which part number do i need for the best DV ? is it revision g or d i need ?
Thanks in advance
Dubbin it since 2006
Offline GTI-Ross
  • Learning All The Time :)
Re: URGENT DV question!
« Reply #1 on: March 13, 2014, 10:02:46 am »
G: no boost leak, and will last fine up to stage 2
Offline Leigh200sx
« Reply #2 on: March 13, 2014, 10:47:42 am »
Mine is stage 2 running 276bhp and a rev g for me
Offline xjay1337
  • -Receive: 377
« Reply #3 on: March 13, 2014, 11:35:11 am »
Do you want a ban?  :sick: :sick: :sick: :sick: :signLOL:
« Reply #4 on: March 13, 2014, 12:14:05 pm »
EVERYTHING ELSE IVE READ SAYS GET REV D ???
Offline xjay1337
  • -Receive: 377
« Reply #5 on: March 13, 2014, 12:36:26 pm »
Revision G is your best bet, that is what everyone recommends?
« Reply #6 on: March 13, 2014, 01:04:39 pm »
REVISION G .... Still uses rubber solonaoid and is 40 quid
REVISION D ..... Uses a piston that will never wear ? and is 60 quid so must be the better surly ??
Offline Nodz
  • -Given: 73
  • -Receive: 103
« Reply #7 on: March 13, 2014, 01:15:26 pm »
I'm K03 and running a Rev G and it is alot better than the D. The D leaks as it doesn't make a perfect seal and gets worse over time. Just get the G and check it at every service and change when needed
Offline GTI5
« Reply #8 on: March 13, 2014, 02:01:50 pm »
The G is still prone to tearing, I've gone back to a D.
In the past I advocated the G but not after this recent tear.
MK6 GTI Revo
MK5 GTI DSG - Gone
« Reply #9 on: March 13, 2014, 02:07:02 pm »
So your saying you love the D ?  :wink:
Offline xjay1337
  • -Receive: 377
« Reply #10 on: March 13, 2014, 02:22:13 pm »
Everyone even Niki at R-tech recommends a rev G valve.
If you want to buy a D then you can, it's a £40 part and takes 15 minutes to replace, i view it as a yearly consumable.
Offline Joshy
« Reply #11 on: March 13, 2014, 02:26:36 pm »
I bought the G valve as I read numerous time that people recommended it. I have no previous experience with them though so I couldn't really say any more than that.
Just a small question though, do I  NEED blue locktite when installing the new DV though?
Offline vRSAlex
  • -Receive: 253
« Reply #12 on: March 13, 2014, 02:39:31 pm »
If you have a K03 based car, then take the DV as being a serviceable item.  Check every year and replace if necessary.  The K03 have the DV sat on the turbo so goes through many hot and cold cycles whilst having oil sprayed on it through the turbo.  Rubber and oil and heat don't mix well and then the valve tears.
Follow AKS tuning on Facebook
Offline GTI5
« Reply #13 on: March 13, 2014, 03:00:46 pm »
It went on the Dyno and ran fine with the D.
« Last Edit: March 13, 2014, 03:02:48 pm by GTI5 »
MK6 GTI Revo
MK5 GTI DSG - Gone
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
« Reply #14 on: March 13, 2014, 04:37:31 pm »
My Ed30 is still boosting hard on the REVISION C!!  :P
Not bad for 66k miles.
