Author Topic: Jetta fog light surround  (Read 890 times)
Offline Sjw_Vw
« on: March 14, 2014, 12:03:53 pm »
How do I remove the fog light surround on my mk5 Jetta?? I've tried searching, But with no luck. Thanks :happy2:
Offline woahnowboys
Re: Jetta fog light surround
« Reply #1 on: March 14, 2014, 12:10:29 pm »
Front fog light grille?
If so, it's just one screw, and then pulls off, sometimes can be quite hard to pull off, and quite scary.. :signLOL:
'87 MK1 Cabby - To be 20vT'd.
MK5 Daily.
Instagram - woahnowboys
Offline Stanipkiss
« Reply #2 on: March 14, 2014, 12:41:06 pm »
woah is right Shane, pull hard at the screw end as the outside has a tab to locate when you push it back in place.
Offline Sjw_Vw
« Reply #3 on: March 14, 2014, 03:48:32 pm »
Ahh right! Thaanks alot guys :happy2:
Offline OSB
  • -Given: 32
« Reply #4 on: March 16, 2014, 07:37:06 am »
I don't know if you have managed to get your grills off yet.
I had real trouble getting mine off - one side eventually, with a lot of tugging. The other side would not budge until I used a trim removal tool (bit like a screwdriver with the end bent up a bit) working my way along and freeing each 'tab' in turn by levering it out of the retaining hole. I also gently warmed the plastic with a hair dryer to give more flexibility.
I put a smear of silicone grease on each tab and hole to make life easier to replace and take off in future.
Best of luck buddy!
Offline Sjw_Vw
« Reply #5 on: March 16, 2014, 07:04:15 pm »
Best of luck buddy!
Thanks, OSB. No I haven't taken them off yet. Going to do it next weekend :)
