Author Topic: Ed30 Temp Gauge Drop When Coasting  (Read 14933 times)
Re: Ed30 Temp Gauge Drop When Coasting
« Reply #15 on: May 02, 2014, 12:41:05 pm »
Stat not bring up a fault code?
How much did it set you back?
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
« Reply #16 on: May 02, 2014, 09:12:34 pm »
Nope. It was still kinda working as it should, just sticking a tiny bit open so the car was about 10 degrees cooler than it should be. Feels much better now.
Part was about £30 from VW, and fitting (inc coolant change) was £200. Ball-ache of a job. I attempted it but gave up.
Offline Markyed30
« Reply #17 on: May 02, 2014, 10:45:15 pm »
I seem to have an issue on dash mine is always 90 but with climate 19/2 I only seem to get over 80 in traffic or sitting at 70 on motorway normal driving I always seem to be around 70 is is this correct?
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
« Reply #18 on: May 02, 2014, 10:57:34 pm »
^ sounds similar to my problem. Gauge showing 90 apart from coasting down hill but climate display was showing around 74 in normal driving. When dash gauge dropped 1 notch, climate would show 71 degrees.
Offline Markyed30
« Reply #19 on: May 02, 2014, 11:06:11 pm »
I'll try a drive tomorrow and check again  but sounds like I'll need to replace my thermostat then  :fighting:
Offline Markyed30
« Reply #20 on: May 02, 2014, 11:11:15 pm »
What would be good is a video of the cruise control temp video from a cold start to 10 min in on average driving, prob find some have an issue and didn't know
Offline skard
  • -Receive: 245
« Reply #21 on: May 02, 2014, 11:50:12 pm »
Since changing mine it has not fluctuated to a low level, and I have been running wih the MFA add-on via FISCON to get oil and water readings whilst driving.
I wouldn't like to guess at how many of these stats have now failed and we are just realising.
Offline paulmni
« Reply #22 on: November 11, 2014, 09:07:07 am »
think I'm in the same boat.  Sits at 90 when sitting in traffic, once I get on to the motorway etc it drops to 70.
VW Quoted £200 all in with a courtesy car :).
Local Indy is £100 labour plus I have to source the part.
AwesomeGTI seem to be a bit of a rip sometimes.
Offline edd30
« Reply #23 on: November 16, 2014, 08:57:22 pm »
guys - do you have the part number for the stat ?
cheers
Offline skard
  • -Receive: 245
« Reply #24 on: November 16, 2014, 09:03:39 pm »
06F121111H for ED30
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
« Reply #25 on: November 16, 2014, 09:04:40 pm »
Offline edd30
« Reply #26 on: November 16, 2014, 09:09:00 pm »
Thanks - that'll learn me for skimming ...
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
« Reply #28 on: December 07, 2014, 10:00:37 pm »
As I said further up in this thread, I attempted It but it was just too tough  :sad1:
Most of the front of the engine has to come off. I got Awesome GTI to fit it in the end
It was the main one (in part number above)
Offline Andy1994
« Reply #29 on: December 07, 2014, 10:07:56 pm »
sorry didnt even realise there was a second page on this, im a mechanic myself so il give it a go, just not a fan of rolling about the ground espcially in this weather
