Author Topic: Brake pad warning light  (Read 2990 times)
Offline brough74
« on: March 14, 2014, 07:38:31 pm »
Does anyone know any common faults with this ?
I keep getting the light on the dash on odd occassions, the brake pads are fine so it must be the wiring.
Initial investigation i think its the NSF wiring but not on the pads.
Any ideas please ? I will be looking into this problem in the next few weeks
PEARL DIAMOND BLACK 3dr GTI
HEATED LEATHER,MULTI FUNCTION WHEEL,
18” MONZA ALLOYS, XENON HEADLIGHTS, FLAT TYRE INDICATOR
LUX PACK AND WINTER PACK
SHARAN AERIAL, GTI TAX DISC HOLDER, R32 REAR LIGHTS
VW RACING FRONT SPOILER
Offline biffobear
Re: Brake pad warning light
« Reply #1 on: March 14, 2014, 07:48:21 pm »
brake fluid level ok?
Offline DanED30GTI
« Reply #2 on: March 14, 2014, 09:19:24 pm »
When mine came on I went to change the pads and the wiring had completely snapped. Luckily the pads were in need of a change anyway. I think you can put the two wires together to complete the circuit and the light will go out. IIRC the wires are only on the NSF as well.
Hope this helps  :happy2:
Offline Degudodger
  • -Given: 53
  • -Receive: 86
    • Flickr
« Reply #3 on: March 14, 2014, 10:33:15 pm »
If the fluid level is where it should be the likely cause is a damaged wear sensor lead. Can be coded out  :smiley:
Offline Marc-5-GTI
« Reply #4 on: March 15, 2014, 09:46:10 am »
As above,
This light came on, on my 58reg polo. The brake pads were fine but the wear indicating wire had broken, I tied the two wires together to complete the circuit, light went out, no need to change my pads until they were worn  :happy2:
Offline andybon
« Reply #5 on: March 15, 2014, 11:02:35 am »
I had the same, like they say the wire had broken/rubbed away and caused a short
How hard can it be?
Offline Veee-dubber
« Reply #6 on: March 15, 2014, 11:41:06 am »
Switch is defo only on NSF bud
Offline brough74
« Reply #7 on: March 15, 2014, 02:33:03 pm »
The fluid is ok as ive only just changed it.
So the issue will probably be the wire then, many thanks guys i will sort this out next weekend when im not working. By either shorting or coding out.
(did not realise it was only on the NSF)
