Author Topic: RNS 510 Installed but......  (Read 5357 times)
Offline QD MBE
  • -Receive: 102
Re: RNS 510 Installed but......
« Reply #15 on: October 07, 2009, 08:05:27 pm »
I fitted them, and used a small cable tie to secure the cables to the RNS.  I secured them to the outer edge of the fan grill, you will see what I mean when you take you set out.
Offline ollie288
« Reply #16 on: October 07, 2009, 09:13:00 pm »
Just been out and removed the adaptor and plug them straight in. It seems to be better but i haven't drove it far so we will see tomorrow.
I had a look at the ground pin on sticker and it was three but I do not understand what I am swapping. They all looked the same. :confused:
Cheers :happy2:
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #17 on: October 07, 2009, 09:42:01 pm »
The cable from two into three and vice versa.
Stu...
Offline ollie288
« Reply #18 on: October 07, 2009, 09:50:26 pm »
ohhhhhh i get you now cheers :happy2:
Offline mortygttdi
  • -Receive: 146
« Reply #19 on: October 07, 2009, 11:06:49 pm »
ollie sorry abit off topic picked my slip ring us today but still waiting for the controller i also ordered a GTD badge for my steering wheel.  It carnt be the adaptor cop ive got the same one there from vw and mine has perfect reception? Ide in with what Stu was saying.
« Reply #20 on: October 08, 2009, 12:05:47 am »
Hi there ollie,
i know this is kinda off topic, but could you tell me if the RNS510 had RCA sockets for the amp leads?
cheers mate  :drinking:
Offline vRStu
  • -Given: 90
  • -Receive: 159
« Reply #21 on: October 08, 2009, 07:20:31 am »
No it doesn't but you could make a flying lead to attach them.
Stu...
  • -Receive: 291
« Reply #22 on: October 08, 2009, 08:30:11 am »
Make sure you pull out the right wire. For some reason, I pulled out the wrong one and only realised after I'd pulled it out. they're a pain in a backside to do.
Offline ollie288
« Reply #23 on: October 09, 2009, 07:52:54 pm »
@ Stealthwolf - Do they just pull out and push back in?
@ anyone Removing the connector has slightly improved it but still no where near as good as it was with my RCD300. Also the clicking is getting worse and even comes on with the navigation voice! Ill have a look at the wires.
So I just swap the earth with 2?
Also what aftermarket speakers would be good for the mk5. As I said early I have a Sub and Blaupunkt 555 amp.
« Last Edit: October 09, 2009, 08:48:53 pm by ollie288 »
  • -Receive: 291
« Reply #24 on: October 09, 2009, 08:39:56 pm »
Taking the individual wires out of the plug is a complete paint the backside. I used a prong of a tweezer to ease the wire. The wires have 'barbs' to keep them in place.
Offline ollie288
« Reply #25 on: November 08, 2009, 10:50:52 am »
Hi there ollie,
Just read this post. No it doesn't. I used a Blaupunkt THA 555 Amp which uses a separate wiring loom. The normal quad-lock goes into the new wiring loom and there is a quad-lock on the new loom which goes into the back of the RNS. That is all that is required to fit it. Its really easy! :happy2:
Offline mclovin
« Reply #26 on: November 09, 2009, 07:01:44 pm »
You can also use a Line Output Converter (LOC) to get a line-level output, I'm making up a plug and play wiring loom right now with a LOC attached to it so I can use it with my amp and sub. I'll write it all up once I've done it and post it up here if that helps?
« Reply #27 on: November 09, 2009, 09:51:52 pm »
 That would be Great!....................Just like your forum name :happy2:
Offline mclovin
« Reply #28 on: November 09, 2009, 10:38:52 pm »
Cheers! The plug and play wiring loom I'm making will also connect up my Bluetooth kit and the MDI kit, but it can easily be built up in stages. It took me ages to dig out all the bits of info I needed, pull it together everything out and get all the right bits so I figured there was a need to put a guide together for anyone else who might want to do this.
I though I'd do it in three parts, LOC/amp connector first, then with bluetooth connection and then with the MDI but the MDI kit has some duplicate parts in it so I'm not sure if that's the right order - Either way I'll figure it out and put something together.
