Author Topic: Stock boost  (Read 5253 times)
Offline clapton712
Stock boost
« on: March 16, 2014, 04:59:23 pm »
Guys, I know this has been asked millions of times before but I just wanted to check something!
My stock GTI is peaking at 16 PSI and tailing off to around 13.5 PSI. Sounds a bit high from what I have read but I may be wrong? I'm not complaining at all! Car runs very well, 2007 BWA engine with 42k.
Sound about right or higher boost than expected? No codes within the ECU.
Offline betty_swollox
  • -Receive: 29
Re: Stock boost
« Reply #1 on: March 16, 2014, 05:10:19 pm »
Do you have proof that it is stock?
2010 Leon CUPRA
BCS Powervalve Exhaust
Revo Ceramic Intake
APR Stage 2
Offline clapton712
Re: Stock boost
« Reply #2 on: March 16, 2014, 05:12:38 pm »
We'll no but I guess it could have had a map in the past. Sounds a bit low for a map to me though!
Is there an easy way to check for maps?
  • -Receive: 29
Re: Stock boost
« Reply #3 on: March 16, 2014, 05:19:49 pm »
Rolling road
I asked a garage about this a while ago and they said there was a way to find if the ecu had been written to but can't remember
You could try vagcom? Do some logging
2010 Leon CUPRA
Revo Ceramic Intake
APR Stage 2
Offline xjay1337
  • -Receive: 377
Re: Stock boost
« Reply #4 on: March 16, 2014, 05:22:03 pm »
Stock psi is peak around 12-13 and hold 8-9 tailing to 6 or 7 at red line
Offline edition30gaz
Re: Stock boost
« Reply #5 on: March 16, 2014, 05:43:03 pm »
Was wondering what the stock boost was, 13psi then?
Offline v4rley
  • -Receive: 104
Re: Stock boost
« Reply #6 on: March 16, 2014, 07:31:38 pm »
Offline clapton712
Re: Stock boost
« Reply #7 on: March 18, 2014, 07:33:19 pm »
So I did some logs earlier and come back with a peak/spike if 17.4PSI and dropping back to 13.5/14PSI. Does this sound like a possible stage I map that's got some problems? Eg the dreaded Divvy valve??
Offline xjay1337
  • -Receive: 377
Re: Stock boost
« Reply #8 on: March 18, 2014, 08:48:52 pm »
Have you checked your DV valve..?
Offline clapton712
Re: Stock boost
« Reply #9 on: March 19, 2014, 07:48:26 am »
Nope, just ordered one last night onthe off chance its split so ill change that with my R8 coils when its all here and see what happens!
Offline clapton712
Re: Stock boost
« Reply #10 on: March 19, 2014, 01:35:02 pm »
Can anyone confrim how loud their turbo spool is on a stock GTI? Can you hear it spool up in the cab and also hear the DV working?
Offline Stevepd
  • -Given: 49
Re: Stock boost
« Reply #11 on: March 19, 2014, 08:55:26 pm »
Nope, nothing really.
Standard 5 Door Shadow blue.
Offline clapton712
Re: Stock boost
« Reply #12 on: March 21, 2014, 09:01:44 pm »
Does anyone know what pressure the over boost fault comes in at on stock maps?
