Author Topic: MK5 GTI (ED30) sump part number  (Read 1964 times)
Offline SteveS
« on: March 16, 2014, 07:47:48 pm »
Any one know the part number for the engine sump and i guess the gasket?
SOLD!! :(
VW GTI Edition 30 No. 0551
Revo Stage2+ (LT) | Evoms Intake, K&N Filter | VWR LSD | Milltek R32 TBE | VWR Engine Mounts | VWR Big Front & S3 Rear Brakes | VWR Springs |  VWR Shortshift | SuperPro Bushes |  Recaro Seats
Offline SI-R32
  • -Receive: 126
Re:
« Reply #1 on: March 16, 2014, 07:48:21 pm »
What's your engine code? And year
Offline doylebros
Offline SteveS
Re: MK5 GTI (ED30) sump part number
« Reply #3 on: March 16, 2014, 08:08:49 pm »
2007, how do i find engine code?
SOLD!! :(
Offline SI-R32
  • -Receive: 126
Re:
« Reply #4 on: March 16, 2014, 08:10:54 pm »
Its in the first page of the service book, unless someone else can chip in, it has 3 digits mine is bub for example
Offline doylebros
« Reply #5 on: March 16, 2014, 08:17:30 pm »
From the text book
Engine number
(VRL005319; Edition 11.2012)
The engine number (“code letters” and “serial number”) can be found on the left on the joint between engine and gearbox.
The engine code is also stamped on the right side of the cylinder head and on the cylinder block.
The engine number consists of up to nine characters (alphanumeric). The first part (maximum 3 characters) makes up the “engine code”, and the second part (6 characters), the “serial number”. If more than 999,999 engines were produced with the same code letters, the first of the six digits is replaced by a letter.
In addition, there is a sticker on the toothed belt guard with “engine code” and “serial number”.
The engine code is also included on the vehicle data sticker.
Vehicles with four digit engine codes
Starting with the letter “C”, new four digit engine codes have been introduced. The first 3 digits denote the mechanical design of the engine and are stamped on the engine as before. The fourth digit denotes the performance and torque rating of the engine and depends on the engine control unit. The four-digit engine code can be found on the identification plate, the vehicle data sticker and the engine control unit.
Offline SteveS
« Reply #6 on: March 16, 2014, 09:00:29 pm »
i have the service book and as you said it has data on the first page.
vin
1k1 3y2
golf gti 30 gti
169kw     6f
BYD-               JQN
LA7W------------- IR
Then loads of sets of 3
« Last Edit: March 16, 2014, 09:03:38 pm by SteveS »
SOLD!! :(
Offline SI-R32
  • -Receive: 126
« Reply #7 on: March 16, 2014, 09:03:58 pm »
sump     06F103601L
gasket   06B103307C
Offline doylebros
« Reply #8 on: March 16, 2014, 09:05:28 pm »
BYD is the code look at the link
Sump Item 22 - 06F 103 601 L - £ 155:46
Frame item 21 - 06B 103 307 C - £17.08
Sealant item 26 - D 176 404 M2 - £23:69
Full retail inc vat
Offline doylebros
« Reply #9 on: March 16, 2014, 09:15:07 pm »
It may also be a case that you think about fitting a new oil strainer - common problem
06F 115 251 A - £31:92
This is well worth a read
http://www.mk5golfgti.co.uk/forum/index.php/topic,68442.0.html
