November 19, 2024, 12:37:21 pm
All Things Mk5
Mk5 General Area
ED30 ecu
Topic: ED30 ecu (Read 604 times)
adamg
Taking part
-Given: 3
-Receive: 2
ED30 ecu
March 19, 2014, 06:37:42 pm »
Hi I have a ecu code number 1k0907115L there is a fault with the ecu, just wondering if anyone knew if i can use an ECU with a different letter at the end im sure ive read somewhere that you can , any help would be appreciated.
Adam
martin@gti.co.uk
Always Involved
-Given: 1
-Receive: 6
Re: ED30 ecu
Reply #1 on:
March 19, 2014, 09:45:43 pm »
you need SKC code from the ECU and you need SKC from donor ECU. I`ve had mine done in germany with immo disabled and remaped all for 450 Euro incl. donor ecu...
otherwise you need virgin ECU 900+ pounds., also if your car is above 2007 you might get it virginized via VW new set a keys and locks and coding via VAS online.
All Things Mk5
Mk5 General Area
ED30 ecu
