Author Topic: Engine oil found on spark plug  (Read 1626 times)
Offline vag12
« on: March 20, 2014, 12:24:43 pm »
Last night I was having bad misfires so took it to garage this morning to change plugs, but frm cylinder 3 the plug had oil at the bottom of it? What can this mean and also since changing plugs I have white smoke coming out of my exhaust? Any idea what it could be?
Offline martin@gti.co.uk
Re: Engine oil found on spark plug
« Reply #1 on: March 20, 2014, 10:43:19 pm »
Most likely PCV valve..common issue, or valve cover gasket...
Offline vag12
« Reply #2 on: March 21, 2014, 10:39:54 am »
PCV is blanked of so out of question, valve cover gasket was changed yesterday still the same
« Reply #3 on: March 21, 2014, 11:16:01 am »
Ok..so white smoke indicates that the coolant is beign burned...might be tge head gasket.. try compression test..
Offline omeydz
  • -Receive: 50
« Reply #4 on: March 21, 2014, 11:16:33 am »
Was it just oil or was the plug very sooty too? If so might check fuel injectors too.
Recently back on the forum! Good to be back
Current Rides
Mazda RX8 231bhp ( very different little rocket lol!)
SOLD
2007 MK5 Golf 1.4 FSI
2007 Golf MK5 GTI DSG
2008 Audi A5 3.0TDI
Offline sean140
« Reply #5 on: March 21, 2014, 11:27:18 am »
Not sure if it's the same, But on my TSI engine, i had the exact same & i needed to have the gasket seal re done.
Apparently on a TSI it wasn't that straightforward to done and half the engine had to be took apart.  :signLOL:
Offline OSB
  • -Given: 32
« Reply #6 on: March 21, 2014, 05:46:36 pm »
White smoke tends to mean water getting into the cylinder - could be head gasket.
Blue smoke tends to be oil burning off.
If you have white smoke and oil on the plug, it points to a head gasket failure.
I hope not but best to get it checked.
Have you got oil in the coolant water? It might only appear as a trace on the surface.
