Author Topic: Free Map v10 for the solution  (Read 2260 times)
Offline V2 FAN
  • Porsche 911 inbound
« on: March 20, 2014, 07:39:41 pm »
Hey Guys
I bought a copy of v10 Maps from ebay, however I want to burn a copy off for a mate at work rather than to loose mine.
I have a Verbatim dual layer DVD - disc and Nero 7, however the copy I made does not work  :fighting:
I simply copied the DVD using the DVD copy feature on Nero at a low burn speed.
Any ideas? I will send a copy of the v10 Maps to anyone that gives me the winning solution  :pomppomp: :pomppomp:
Bloody discs are expensive so I don't want to be burning lots
Thanks one and all  :happy2:
Offline STV4R
Re: Free Map v10 for the solution
« Reply #1 on: March 20, 2014, 07:46:35 pm »
This for RNS or MFD2?
Edit: You also say you use a DL DVD- if thats correct, i believe you need to you use a DL DVD+ and have burn speed as slow as possible.
« Last Edit: March 20, 2014, 07:53:02 pm by STV4R »
Offline V2 FAN
« Reply #2 on: March 20, 2014, 07:51:28 pm »
Sorry RNS 510
Offline STV4R
« Reply #3 on: March 20, 2014, 07:56:06 pm »
Well the RNS should play copy DVD's fine. So just use a DL DVD+R disc and burn as slow as possible. If still doesn't work it could be the burner your using.
Also you should burn with IMGBurn its free and the best image burner there is
Offline V2 FAN
« Reply #4 on: March 20, 2014, 08:00:10 pm »
Thanks I'll try that.
If it works I'll send you a copy if you like  :happy2:
Offline STV4R
« Reply #5 on: March 20, 2014, 08:01:05 pm »
I dont need a copy but thanks :happy2:
Offline V2 FAN
« Reply #6 on: March 20, 2014, 08:03:28 pm »
Your a gent thanks
Offline chrisr763
  • -Receive: 62
« Reply #7 on: March 20, 2014, 08:56:57 pm »
Your a gent thanks
Just for reference - Did the above solution work?  :happy2:
Offline Viking
  • -Given: 17
  • -Receive: 47
« Reply #8 on: March 21, 2014, 04:19:26 pm »
Different media makes a difference. I burnt a load of coasters with Verbatim discs, but as soon as I swapped to Aone Plus discs it managed it straight away.
Sarcasm for free. Anything after that can only be considered as a bonus.
Just because you think you know something, doesn't make you an expert if you've just read it on the internet, y'know.
Offline V2 FAN
« Reply #9 on: March 21, 2014, 06:56:09 pm »
Quote
Not tried it yet been sooooooooooo busy but I'll try either this evening or tomorrow morning.
I will report my findings  :happy2:
« Last Edit: March 21, 2014, 06:57:44 pm by V2 FAN »
Offline Gti_Mad
« Reply #10 on: March 21, 2014, 07:22:22 pm »
any chance of a copy  :signLOL:
Offline V2 FAN
« Reply #11 on: March 21, 2014, 09:58:19 pm »
I don't mind sending a couple out, I have borrowed a windows PC to burn these discs as I'm not sure if the Mac software will do the same job or not.
I need to buy some discs therefore there will be a small fee for this, but first let me try and burn a working copy.
 :drinking:
Offline SkyJawa
« Reply #12 on: March 21, 2014, 11:08:53 pm »
I've had the same with verbatim that everyone bangs on about, I'll try those instead. Out of interest what ver is your RNS?
Offline Viking
  • -Given: 17
  • -Receive: 47
« Reply #13 on: March 22, 2014, 06:30:08 am »
Mine's a C revision, but I had the same V10 maps loaded on my old A revision. As for media, I use DL DVD +R. As said earlier, I thing the DVD -R are not so good either.
Offline STV4R
« Reply #14 on: March 22, 2014, 09:47:19 am »
You guys do know you can download the maps for free....?
Just head over to www.gpsunderground.com
