Author Topic: Dump valve  (Read 947 times)
Offline daz164969
Dump valve
« on: March 21, 2014, 08:05:11 pm »
Has anyone fitted a dump valve and what is the best make? Thanks :happy2:
  • -Receive: 427
Re: Dump valve
« Reply #1 on: March 21, 2014, 08:07:34 pm »
Mk5 Golfs have a divrter valve and not a dump valve. Best one is the OEM Revision G, £35 from your local dealer.  :happy2:
Offline Dallen75
Re: Dump valve
« Reply #2 on: March 21, 2014, 09:59:17 pm »
Forge do two different spacers if it's noise your after ? One fixed, Full blow off and the other, an adjustable one which has 3 settings, fully blow off which is loud, partial blow off/ partial re-circulate, slightly quieter and then full recirculate which is quiet and will help the car keep stronger boost. These are bolted onto the diverter valve. I personally don't have a dump valve just a revision D diverter valve which I will prob swap for a G soon. A nice induction kit and a standard diverter D or G revision combo will sound and perform better than adding a spacer just for noise. Each to their own I suppose
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
Re: Dump valve
« Reply #3 on: March 22, 2014, 08:05:46 am »
The forge spacer sounds terrible and actually LOSES power as it leaks.
If you want loud blow-off noises you should consider a scooby  :happy2:
Offline Gra
Re: Dump valve
« Reply #4 on: March 22, 2014, 08:25:58 am »
As above there release the pressure while boosting sometimes sounds like a tyre leaking a gush of air lol
Offline cuprajake
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,72567.0.html
Re: Dump valve
« Reply #5 on: March 22, 2014, 08:36:00 am »
Even running vta dv on scoobs is wrong.
Any maf based car should not vta.
Tornado red ed30 #0728
Offline SurreyED30
Re: Dump valve
« Reply #6 on: March 22, 2014, 11:13:40 am »
Forge spacer sounds like a bus  :signLOL: :signLOL: :signLOL:
