Author Topic: strange sidelight problem  (Read 3007 times)
Offline jakex181
« on: March 22, 2014, 06:49:35 pm »
Ive been having some weird issues with my sidelights. the other day the dash light came on for a broken bulb so i checked and it was a side light, i checked the bulb and it was fine so i put it back in and reset the fault code (as i believe the car cuts power to the bulb when its gone?) it started working again however now the other side has stopped working :/ any ideas? cheers
Offline alexharvey
Re: strange sidelight problem
« Reply #1 on: March 22, 2014, 09:17:42 pm »
change that bulb?
Offline Wooosh
  • -Receive: 87
  • Factory ponies.
« Reply #2 on: March 24, 2014, 12:27:52 am »
Change the bulbs and get the car scanned for any fault codes.
Stage 2 MK5 GTI Revo GONE
Stage 1+ MK5 GTI R-Tech GONE
Offline jakex181
« Reply #3 on: March 24, 2014, 08:01:10 am »
The side light has just started working again and the dash light has gone out :/
Offline john87
  • -Receive: 53
« Reply #4 on: March 24, 2014, 09:46:58 am »
I've had this.. it's basically a sign that the filament is loose or just about to fail completely within the bulb. If you don't change them now, you probably will have to in the next couple of weeks  :happy2:
Offline jakex181
« Reply #5 on: March 31, 2014, 05:06:08 pm »
Thankyou mate!! ive checked the bulbs and they looked fine so was really strange, i also scanned the car and it read this:
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
   Part No SW: 3C0 937 049 E    HW: 3C0 937 049 E
   Component: Bordnetz-SG     H37 1002
   Revision: 00H37000    Serial number: 00000004246535
   Coding: E78F8F2700041500001400001400000000087F075C
   Shop #: WSC 00000 785 00200
   VCID: 2B5F19758A1E111
   Subsystem 1 - Part No: 1K2 955 119 E  Labels: 1KX-955-119.CLB
   Component: Wischer 210606 020  0501
   Coding: 00038805
   Shop #: WSC 00000
   Subsystem 2 - Part No: 1K0 955 559 AE  Labels: 1K0-955-559-AF.CLB
   Component: RLS     180606 014  1201
   Coding: 00208933
   Shop #: WSC 00000
1 Fault Found:
02395 - Parking Light Right Front (M3)
            012 - Electrical Fault in Circuit
             Freeze Frame:
                    Fault Status: 01101100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 234
                    Mileage: 138840 km
                    Time Indication: 0
             Freeze Frame:
                        ON
                    Voltage: 12.35 V
                        ON
                        ON
                        OFF
                        OFF
                        OFF
Ill get some new bulbs though cheers for the help :)
Offline Melvin084
« Reply #6 on: March 31, 2014, 07:20:55 pm »
I have exactly the same problem,  I have tried changing the bulbs and still nothing I also checked all my fuses and there okay
+now the same thing is happening with one of my license plate lights
