Author Topic: Cv boot part number vw or any other decent cv boot recommendations  (Read 2199 times)
Offline Airz182
Got a clicky cv joint on my car so thought it would of be easier to replace whole shaft rather than mess about changing the joint! Anyway got hold of another shaft from one being broken, but boot has split near the clip, still plenty of grease inside tje gaitior and on joint, so should still be fine, but want to get new boot before fitting it, anyone know part number from vw cheers
Instagram- airz182
Offline SI-R32
  • -Receive: 125
Re: Cv boot part number vw or any other decent cv boot recommendations
« Reply #1 on: March 23, 2014, 07:35:37 pm »
year of car plus 3 digit engine code will help out
Offline doylebros
« Reply #2 on: March 23, 2014, 07:37:41 pm »
As above plus also add if 6 speed 5 or DSG
Offline Airz182
« Reply #3 on: March 23, 2014, 08:03:39 pm »
Oh right, its 05plate dsg think engine code maybe axx with it bring a 05? Cheers
Instagram- airz182
Offline SI-R32
  • -Receive: 125
Re:
« Reply #4 on: March 23, 2014, 08:10:33 pm »
Outer boot 1k0 498 203A approx 23 quid
Offline Bazgti
« Reply #5 on: March 23, 2014, 08:13:38 pm »
Sorry to cut in on your post but would this the same part number as 56reg, manuel?
Offline SI-R32
  • -Receive: 125
« Reply #6 on: March 23, 2014, 08:15:05 pm »
same engine code?
Offline Blue GTI
« Reply #7 on: March 23, 2014, 08:17:44 pm »
Try jandrcvjoints.co.uk, got whole drive shaft with both joints for £40, easier to fit than messing about with the boot for the money.
Offline doylebros
« Reply #8 on: March 23, 2014, 08:22:23 pm »
Yes - £23.68 full retail inc vat
Offline Bazgti
« Reply #9 on: March 23, 2014, 08:28:21 pm »
There's none gen ones on eBay for less than half that. Won't be much different surely?
Offline doylebros
« Reply #10 on: March 23, 2014, 08:33:20 pm »
I've found the cheaper ones fit but don't last, so if you like doing the job more often then fit the cheaper ones!
Offline Bazgti
« Reply #11 on: March 23, 2014, 08:39:05 pm »
Nuff said... £23 it is then  :happy2:
Offline Airz182
« Reply #12 on: March 23, 2014, 09:05:17 pm »
Will do as the other side is clicking aswell but not as bad as the one im replacing now
Instagram- airz182
Offline Airz182
« Reply #13 on: March 23, 2014, 09:07:00 pm »
Does the car being on coilovers have anything to do with the cv joints going?
Instagram- airz182
Offline Airz182
Re:
« Reply #14 on: March 23, 2014, 09:07:56 pm »
Thanks alot, is this vw retail
Price?
Instagram- airz182
