Author Topic: Stereo Randomly lowers sound  (Read 1811 times)
Offline Melvin084
« on: March 23, 2014, 07:43:33 pm »
Sometimes when I comeback from uni I feel very tired so I put my music on full blast so I don't fall asleep while driving
Now! the problem I have been having recently is that the sound automatically lowers itself for some reason, i raise the volume and it comes back down again. This has been happening for the last two days and its pretty annoying
Does anyone know why?
I have the standard stereo by the way http://i1.ytimg.com/vi/Ts3emdPBwSM/maxresdefault.jpg
Offline xjay1337
  • -Receive: 377
Re: Stereo Randomly lowers sound
« Reply #1 on: March 23, 2014, 08:08:33 pm »
No reason why it should. Does the volume display indicate it's turning down?
Maybe it's a sign saying you should pull over, have some caffeine and a nap..
Offline Adam-golf
  • Derv!
« Reply #2 on: March 23, 2014, 08:17:12 pm »
I had a similar thing on my rcd-510, the volume would go up and down for a few mins and then the volume control wouldn't work.
Never found out why it done it but fixed it by fitting a mfsw
Offline mb
  • -Receive: 29
« Reply #3 on: March 24, 2014, 04:12:26 pm »
My RCD510 was doing this the other day, the display was even showing the volume changing. All I did to 'fix' it was switch the stereo off and turn the volume control button round several times.  I've got a MFSW so never touch the volume control on the stereo itself so think the contacts may of needed a bit of a clean or something
Offline m1kee
« Reply #4 on: March 25, 2014, 04:15:27 pm »
Hi is that not your GALA setting? Automatically adjusts..check your system settings...
Offline GLIDN
« Reply #5 on: March 26, 2014, 01:25:23 am »
I was also going to suggest the Gala as well.
Offline Melvin084
« Reply #6 on: March 26, 2014, 02:37:03 am »
No it doesn't jay, haha if I did that I would get home by midnight :signLOL:
Cheers lads, Im going to have a look tomorrow to see if this so called gala setting is active or not
Offline mb
  • -Receive: 29
« Reply #7 on: March 26, 2014, 03:11:41 am »
Wasn't GALA setting in my case as I don't use it. Also when the volume did change by itself it displayed on the stereo
