Author Topic: Stuttering under load  (Read 2933 times)
Offline Sickness
« on: March 25, 2014, 07:17:12 pm »
Hi,
Have a 2006 mk5 gti with 95k on the clock.
The car suffers from stuttering under heavy acceleration in all gears when in a low rev range, read lots on it on various forums but never seems to be a solution. So far ive changed the DV to the GFB one and changed the spark plugs with one plug covered heavily in soot. Changing plugs didnt make a difference but what would cause sooting on one plug, bad injector?
Andy
Offline Human Joist
Re: Stuttering under load
« Reply #1 on: March 25, 2014, 07:56:24 pm »
Have you had it fault coded to see if there is anything logged
Offline Sickness
« Reply #2 on: March 25, 2014, 08:01:21 pm »
a friend who's a mechanic ran it through VAG com but no errors showed up.
« Reply #3 on: March 25, 2014, 10:25:35 pm »
Is your car mapped or stock?
Offline burger187
« Reply #4 on: March 26, 2014, 12:23:21 am »
is it a DSG?
Offline 56OctyVRS
  • -Receive: 72
« Reply #5 on: March 26, 2014, 12:42:46 am »
Have you changed your fuel filter recently and cam follower?
Offline GrayMK5GTI
  • -Given: 125
  • -Receive: 248
« Reply #6 on: March 26, 2014, 07:40:33 am »
My old GTI used to stutter under load. No fault codes either, I never fixed it but I think the LPFP was failing
Offline john87
  • -Receive: 53
« Reply #7 on: March 26, 2014, 09:55:27 am »
Coil Packs!   :happy2:
Stuttering under load is a telltale sign of ignition problems, most often caused by (common fault) failing coil packs and/or dirty spark plugs. Change 'em out.
Offline xonk
« Reply #8 on: March 26, 2014, 03:50:24 pm »
I didn't have the same issue as you but there was a recall from VW about coil packs from a certain year, mine is a 05 and got them done free of charge when i went in for my last service so there may be issues with these older ones!
Offline Sickness
« Reply #9 on: March 26, 2014, 05:36:24 pm »
its a manual and stock, forgot to say i did have the cam follower done but it made no difference. Not done the fuel filter, Ill try the coil packs and see if it makes a difference.
Ill give VW a call and see if it came in as part of any recalls.
Offline LiamGTi
« Reply #10 on: March 26, 2014, 10:31:24 pm »
First things I'd be looking at are,
Change Spark Plugs,
Change Fuel Filter,
If it persists then change Coils.
I had the same with my Bocanegra, new Sparks sorted it straight away.
