Author Topic: Revo Pcv upgrade  (Read 7756 times)
Offline formulaclean
Revo Pcv upgrade
« on: March 26, 2014, 11:22:33 am »
Morning :)
looking at the revo pcv upgrade as i need a new pcv valve anyway.
DO you need to run a oil catch tank with this? or can you run without?
what are the pros and cons
J
Re: Revo Pcv upgrade
« Reply #1 on: March 26, 2014, 12:08:53 pm »
The fixing plate for the pcv revamp is different to the one for the catch can kit.
Offline Pikey Motorsports
« Reply #2 on: April 02, 2014, 01:05:33 am »
no you dont need to run catchcan.. there are 2 different pcv plates 1 has outlets for catchan if you want to run one, the other doesnt if you dont
TSR PERFORMANCE GTX30 520BHP
LITCHFIELD R35 GT-R 660BHP
MSL E63 AMG 720BHP
HCP BM3 M5 800BHP
Offline th3_f15t
  • -Receive: 183
« Reply #3 on: April 20, 2014, 08:19:58 pm »
Is there any reasons that you shouldn't use the PCV delete over a full catch can system? Thinking of doing this myself.
Offline 56OctyVRS
  • -Receive: 72
« Reply #4 on: April 20, 2014, 11:35:59 pm »
Both in my opinion and experience are  not needed. My car performed better with the latest pcv valve. The pcv delete will stop any issue of a pcv failing but wont stop the recirculation of oil in the air and neither will a catch can. Under boost the rear pcv valve vents the pressure back into the Intake and that is where the majority of the oil on the intake valves is from. Id stick with the oe pcv as race cars in the VW race series use them with no issues and their engines are used to the extreme during a race.
Offline th3_f15t
  • -Receive: 183
« Reply #5 on: April 21, 2014, 03:26:49 pm »
Thanks for that. I don't currently have any issues, but was thinking ahead. Latest revision it is then.
« Reply #6 on: April 29, 2014, 01:11:44 am »
Depends on the car your average k03/04 car not really unless running big boost on a big turbo then you get alot of blowby and can basically be a necessity
MSL E63 AMG 720BHP
HCP BM3 M5 800BHP
Offline 56OctyVRS
  • -Receive: 72
« Reply #7 on: April 29, 2014, 09:54:54 am »
Most of the oil vapour that gets on to the valves is from being vented through the rear pcv valve. A catch can does nothing to stop these vapours getting through and only stops the oil vapour from intake side when off boost or vacuum, which is very little when you are driving. They do very little to stop build up of carbon and are not worth the money.
« Reply #8 on: April 29, 2014, 10:24:27 am »
Doesn't the latest PCV have a check valve at the rear to help?
One thing I'll say about race cars and the kit they use.  It kind of does prove that the kit is upto the job, however they are on a weekly maintenance schedule and every thing checked after each outing possibly being replaced more often than you think. (Or not replaced, I don't know)
Offline th3_f15t
  • -Receive: 183
« Reply #9 on: April 29, 2014, 05:32:20 pm »
So how does this help? I'm interested in knowing... :smiley:
« Reply #10 on: April 29, 2014, 05:34:30 pm »
A check valve will only allow flow (whether it be oil vapour, air, fluid) one way.  Guessing it has a benefit if Vw saw the need to add it to the latest revision of PCV?
