Author Topic: Valve query  (Read 1036 times)
MPS
Valve query
« on: March 27, 2014, 03:02:09 pm »
I suspect I have a leaking metal valve on my wheel - can it be replaced with a rubber one or will only the metal ones work?
ELSA only states that the entire valve should be replaced at every tyre change - it doesn't mention anything about it being OK to substitute metal for normal rubber valves?
Offline OEM+ DUB
Re: Valve query
« Reply #1 on: March 27, 2014, 04:55:07 pm »
If you have the 'hollow tech' BBS Monza II wheel with part number suffix 'AH' then you can only fit the metal valve due to the hollow spokes.
Hope this helps!
OEM+ 2005 GTI DSG (high factory standard spec and upgraded with S3 alloy hubs, S3 alloy wishbones, Bilstein B8s and VWR springs by my own hands) owned since 2008 and still loving it!
Re: Valve query
« Reply #2 on: March 27, 2014, 05:04:00 pm »
This one Part number  1K0601361
MPS
Re: Valve query
« Reply #3 on: April 06, 2014, 08:44:55 pm »
Thanks all  :happy2:
MPS
Re:
« Reply #4 on: April 10, 2014, 10:04:28 pm »
So is there a replaceable valve inside or not?
Sent from my HTC Desire X using Tapatalk
Offline Teutonic_Tamer
  • -Given: 88
  • -Receive: 95
Re:
« Reply #5 on: April 11, 2014, 09:28:47 am »
There is a removable and replaceable conventional valve core inside them (just like on any Schrader valve - how else would they deflate the tyre before removal).  The actual outer metal body does not need changing every tyre change - the only time they should be changed is if they've been removed from the wheel - say for refurb.  Of course, if there are any actual leaks between the valve body and wheel - then change it.
MPS
Re:
« Reply #6 on: April 11, 2014, 12:14:58 pm »
^ Great stuff, thanks for the info
