Author Topic: probs since cam follower change  (Read 1640 times)
Offline bower
« on: March 27, 2014, 08:51:01 pm »
my car has a problem when not fully warmed up, at around 20k revs when accelerating the whole car seems to shake, judder, its hard to explain it lasts till about 30k revs then its stops and then once warmed up its fine through all the revs.
ive just realised after changing the spark plugs etc that it all started after i replaced the cam follower. im not sure what the follower actually does but could it be related to the probs im having? also no faults on vcds
« Last Edit: March 28, 2014, 06:15:11 am by bower »
Re: robs since cam follower change
« Reply #1 on: March 27, 2014, 09:47:04 pm »
You would blow your engine well before 20k revs.  :scared:
Was your previous cam follower ok when you replaced it?
Sounds to me like you may have a coil pack issue. As you have vcds, do some live logging of blocks 015 and 016 to see if you're getting a misfire.
Offline bower
Re: probs since cam follower change
« Reply #2 on: March 28, 2014, 06:17:34 am »
cheers for replying.
the old cam follower had a bit of wear on the face but was ok and ive done some logging and it was showing no probs on misfire?? :confused:
and lol i meant 2k
« Reply #3 on: March 28, 2014, 09:48:58 am »
Did you log when stationary or on the move?
Offline martin@gti.co.uk
« Reply #4 on: March 28, 2014, 10:40:09 am »
Any VCDS stored faults at engine ecu? Is your manual or dsg?
What you are describing sounds bit like dual mass flywheel starting to fail..
« Reply #5 on: March 28, 2014, 10:58:00 am »
Offline martziniuk
« Reply #6 on: March 28, 2014, 05:56:10 pm »
Did you get any muck in the fuel lines whilst changing the follower?
Offline bower
« Reply #7 on: March 28, 2014, 08:02:59 pm »
if it was flywheel wouldnt it do it regardless of engine temp? i really dont know its baffeling me. its a manual and i did the measures while driving.
i dont think i did, would it effect the car the way im describing if i did?
cheers
Offline martziniuk
« Reply #8 on: March 28, 2014, 10:54:13 pm »
I had the same issue, it would do it when cold only at 2-3k. You can log the misfires on a counter in VCDS which won't show as a fault code if there's not enough misfires to trip the EML.
I fixed mine when I went K04, I presume changing the injectors fixed it.
