Author Topic: Few RNS510 Questions  (Read 1120 times)
Offline Betty02
    • iBett
« on: March 28, 2014, 01:47:04 pm »
Mates got a Mk5 R32, factory fitted RNS510, not sure which version but I don't think it's the C LED version! Anyway Basically I was wondering how he finds out his firmware and what's the latest version he can upgrade too, how does he upgrade and any download links?
Also whats the latest map version that works best with that firmware?
Cheers chaps!
Simon
ADMIN NOTICE: Please do not use the site for advertising!
Offline Viking
  • -Given: 17
  • -Receive: 47
Re: Few RNS510 Questions
« Reply #1 on: March 28, 2014, 01:51:23 pm »
Firmware and how far you can go is dependant on hardware. Pull the unit and look at the label to find the hardware and decide on a firmware upgrade according to that.  Maps shouldn't be an issue with any firmware as I had the latest maps (V10) on an A revision unit.
Sarcasm for free. Anything after that can only be considered as a bonus.
Just because you think you know something, doesn't make you an expert if you've just read it on the internet, y'know.
Offline Betty02
    • iBett
« Reply #2 on: March 28, 2014, 02:57:02 pm »
That the only way to tell? pulling it out? Not access a menu or anything?
Offline Viking
  • -Given: 17
  • -Receive: 47
« Reply #3 on: March 28, 2014, 03:09:46 pm »
If it's had a firmware update at some point then that can and will change the hardware notification in the settings menu. You can check the hardware with VCDS or by the menu system, but if it's been updated previously then it'll report incorrectly. Upgrading the firmware based on software reported settings could brick your unit, so caution.
The only sure fire way is to remove it and read the label.
« Reply #4 on: March 28, 2014, 03:20:05 pm »
Are you sure it's a rns510 as I thought the mk5 never had that model offered as an optional extra.
Offline SI-R32
  • -Receive: 125
« Reply #5 on: March 28, 2014, 03:23:18 pm »
from 57 onward the 510 was an option after they dropped the mfd2
Offline J400uk
  • -Receive: 27
« Reply #6 on: March 29, 2014, 10:09:20 am »
Yep late mk5s definitely had it
