Author Topic: Wet look  (Read 4166 times)
Offline nads1_uk
Wet look
« on: March 28, 2014, 10:02:14 pm »
I've got a diamond black mk6 gti and I'm trying to get the 'wet look'.
At present I'm using cg no touch snow foam followed by cg shampoo then clay. For polish it's again SRP then collinte 476 on top. I've ran out of SRP polish and I'm low on the snow foam.
Is there any products people can recommend to get the look I'm after?
Any ideas would be appreciated.
Andy
Offline markc
Re: Wet look
« Reply #1 on: March 29, 2014, 12:32:59 am »
Had: Edition 30, 3 Door Manual, Pearl Black, Cruise Control, IPod Prep, Arm Rest, Auto Lights and Wipers
Re: Wet look
« Reply #2 on: March 29, 2014, 08:39:35 am »
90% of the final effect is in the prep work ie everything up until you apply the wax.
Offline nads1_uk
Re: Wet look
« Reply #3 on: March 29, 2014, 08:53:11 am »
Have you got any product recommendations bearing in mind I'm doing everything by hand?
Andy
Re: Wet look
« Reply #4 on: March 29, 2014, 09:03:21 am »
None. Machine polishing and then jewelling is what you need.
Re: Wet look
« Reply #5 on: March 29, 2014, 09:16:25 am »
Wet sanding
Offline Attention2Detail
Re: Wet look
« Reply #6 on: March 29, 2014, 09:49:42 am »
A finely prepped surface finished with Prima Amigo & protected with your sealant/wax of choice :notworthy:
Offline cuprajake
  • My Ride: http://www.mk5golfgti.co.uk/forum/index.php/topic,72567.0.html
Re: Wet look
« Reply #7 on: March 29, 2014, 01:54:45 pm »
Tornado red ed30 #0728
Re: Wet look
« Reply #8 on: March 29, 2014, 02:13:39 pm »
Thats how to do it tho. remove all of the orange peal and get a totally smooth "glass" like surface.
Re: Wet look
« Reply #9 on: March 29, 2014, 03:04:45 pm »
Can also be achieved without wetsanding.
Offline Pete-r
Re: Wet look
« Reply #10 on: March 29, 2014, 03:11:20 pm »
While I'm not sure how it compares to others in terms of which is best, mŷ regime is:
Meg's gold shampoo wash and rinse
CG lube and Meg's clay, then dry.
Optional machine with menzerna polish/finisher and a medium foam or soft waffle pad.
CG Jetseal 109 always after machining.
CG black polish, though the R222 will be what I'm trying next after I've used it up.
Wheels bilberry, then dry, then jetseal.
Here is my car right now. No photoshopping but the pic is through a patio door so a shade darker than in the flesh...
« Last Edit: March 29, 2014, 03:36:48 pm by Pete-r »
Re: Wet look
« Reply #11 on: March 29, 2014, 03:18:28 pm »
I love R222. It's what I use on the car around GTI inters last time and it looked awesome. Poor durability though - needed topping up every three weeks.  You are best applying it to paintwork rather than on top of a sealant, and I would ensure tar spots are removed prior to claying.
Offline cuprajake
Re: Wet look
« Reply #12 on: March 29, 2014, 04:22:47 pm »
I fully wet sanded my car, but I know how to do it lol.
Need to be very careful indeed.
Offline JoeDarKa
  • -Given: 57
  • -Receive: 74
Re: Wet look
« Reply #13 on: March 29, 2014, 07:18:23 pm »
Black hole?
Offline xjay1337
  • -Receive: 377
Re: Wet look
« Reply #14 on: March 29, 2014, 08:41:27 pm »
Wet sanding is a whole other world of pain.
Plenty of reasons why you shouldnt. Normal machine correction is normally fine.and wet sanding should only follow machining if the results are not gotten.
Knowing when to stop is important
