Author Topic: Reversing light & rear fog light failure  (Read 7120 times)
Offline Stevepd
  • -Given: 49
« on: March 29, 2014, 02:27:00 pm »
I had the dash board symbol on start up this morning with the 2 message texts for the 2 bulbs failed. I've got 2 new bulbs and changed them but upon start up I got the same symbol/message and checked the lights are actually not working. I've dived into the hand book which states a fuse under the bonnet for the fog but no mention of the reversing light fuse. Anybody any info plus isn't it strange for these to go together. Everything else works.
« Last Edit: March 29, 2014, 06:15:42 pm by Stevepd »
Standard 5 Door Shadow blue.
Offline andy7ven
  • -Receive: 30
Re: Reversing light & rear fog light failure
« Reply #1 on: March 29, 2014, 05:10:40 pm »
Offline homesqueeze
  • -Given: 32
  • -Receive: 43
  • Got another Golf!
« Reply #2 on: March 29, 2014, 05:23:10 pm »
I had a similar problem... Does the boot still open?
http://www.mk5golfgti.co.uk/forum/index.php/topic,19672.msg272635.html#msg272635
Yeah, I had this too. If boot wont open and rear wiper doesn't work as well then its that broken wire.
Offline Stevepd
  • -Given: 49
« Reply #3 on: March 29, 2014, 06:20:18 pm »
Thanks both, the boot does still open but the wiper gave up (or wouldn't stop!) so pulled the fuse. I've had a further look and found the 2 wiring gaiters have been spliced and 1 wire on each side has been cut and crimped. I've left the rubber boots open so I can have another look tomorrow.
Offline Stevepd
  • -Given: 49
« Reply #4 on: March 31, 2014, 05:47:11 pm »
I got the electrician at work to have a quick look today. Somebody has been there previously with the electrical tape still intact. Removal revealed the obvious cut to the rubber boot and a red & yellow wires were crimped together but badly on both sides. To get better access I scalpled the cut a bit more on the left hand boot which showed a brown wire and 3 small white wires broken and another ready to go. All the wires were recrimped adding a bit of extra wire to cope with the opening/closing. All the lights now work but the wiper is still fubard, so fuse removed again UFN.
