Author Topic: RCD 510 can bus  (Read 1790 times)
Offline xonk
RCD 510 can bus
« on: March 31, 2014, 12:28:02 pm »
Hi,
Just picked up an RCD 510 from a friend and have a 2005 GTI. After reading on the forum I see i also need an upgraded CAN bus. Do you know where the best place to pick one of these up? I just missed one in the for sale section I believe.
thanks
Offline Luka
Re: RCD 510 can bus
« Reply #1 on: March 31, 2014, 12:30:09 pm »
Sold - 2006 Tornado Red GTI 3dr
Offline xonk
Re: RCD 510 can bus
« Reply #2 on: March 31, 2014, 01:27:27 pm »
OK great that was quick, is there any programming needed or should it be plug and play
can you pm me details,
Offline Degudodger
  • -Given: 53
  • -Receive: 86
    • Flickr
Re: RCD 510 can bus
« Reply #3 on: March 31, 2014, 01:35:45 pm »
You will need to program the Gateway using VCDS. If you don't have VCDS, you can locate your nearest friendly forum member here - http://www.mk5golfgti.co.uk/forum/index.php/topic,120.0.html
Offline xonk
Re: RCD 510 can bus
« Reply #4 on: March 31, 2014, 04:42:18 pm »
thanks for the info, a big list but nobody near Dublin, I see the cable is not that cheap either!
if the Radio came from a similar car would this work or would it require details of mine via VCDS to work?
Offline Degudodger
  • -Given: 53
  • -Receive: 86
    • Flickr
Re: RCD 510 can bus
« Reply #5 on: March 31, 2014, 04:44:45 pm »
My advice would be to speak with Eddie-NL as he can provide pre coded Gateways meaning it will be plug and play  :smiley:
Offline DamoP
  • -Receive: 115
  • 2007 Edition 30 number 1242
Re: RCD 510 can bus
« Reply #6 on: March 31, 2014, 05:14:11 pm »
his contact details , you need to post one more reply before you can private message
http://www.mk5golfgti.co.uk/forum/index.php?action=profile;u=2345
MDI Armrest & Glovebox kits
Armrests, cloth and leather
Offline xonk
Re: RCD 510 can bus
« Reply #7 on: March 31, 2014, 05:42:53 pm »
Brilliant, thanks for all the advice
