Author Topic: Quick brake info  (Read 796 times)
Offline Johnny_tro
Quick brake info
« on: April 02, 2014, 08:50:21 pm »
Can someone please confirm for me
Discs size
Gt
Gti
R32
And are the pads the same for the gt and gti?
Offline Little_Dave
Re: Quick brake info
« Reply #1 on: April 02, 2014, 08:53:45 pm »
Not sure about the GT but the GTI is 312mm and the R32/S3 are 345mm  :happy2:
Dave
Offline xjay1337
  • -Receive: 377
« Reply #2 on: April 02, 2014, 08:54:48 pm »
GT is a spec level.
Not a model.
TDI 170s get 312mm brakes i believe all others are 288.
And the 288mm and 312mm take same pads apparently.
Offline th3_f15t
  • -Receive: 183
« Reply #3 on: April 02, 2014, 08:57:59 pm »
Www.brake parts.co.uk - good site to reference sizes of pads and discs.
Offline Johnny_tro
« Reply #4 on: April 02, 2014, 09:20:26 pm »
Just checked that site and it's not clear...
R32 is 345mm
But it states the gt, gti have 3 options 280, 288 and 312
How you know which to get? Other than measuring your own?
Offline skard
  • -Receive: 245
« Reply #5 on: April 02, 2014, 09:27:57 pm »
The 1.9 tdi and smaller capacity petrols have 280mm discs.
2.0 tdi (pre-facelift GT) has 288mm discs, the GT170 and GTI have the same 312mm discs, both the 288/312 setup use the same pad and caliper, just different carriers.
The pads to look at between 280 and 288/312 are very different.
If you have a 140bhp diesel in standard form then you will have the 288mm setup
Offline Johnny_tro
« Reply #6 on: April 02, 2014, 09:48:43 pm »
Skard - thank you  :happy2: legend
I have the pre face lift gt so this will ave the 280mm discs. If I upgrade to gti fronts and rears Its not just the carriers i need then? I though calipers were the same.
 Ii would need to ask for discs and pads for a 312mm gti with pads to match? For the same year?
As the
Offline skard
  • -Receive: 245
« Reply #7 on: April 02, 2014, 09:51:23 pm »
You'll have 288 not 280.
For the front it is just carriers and discs to go 312
